Old 04-18-2010, 09:07 PM   #1
tnmssmonte
1970 Blazer body swap to 88' K5 frame
I have been looking and searching for any information about the 1970 K5 blazer frames and the 1980's K5 blazer frames. I have a 1970 Blazer body and am wondering if I can put it onto a 1988 K5 frame. If its possible are there any changes that need to be made? Thanks for the help
tnmssmonte is offline   Reply With Quote
Old 04-18-2010, 10:51 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 1970 Blazer body swap to 88' K5 frame
They are different wheel base lengths and frame widths.
cheick out http://coloradok5.com/specs.shtml for general specks.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-19-2010, 07:52 PM   #3
Mike C
Mike C's Avatar
But it's easy to swap almost all the '85 running gear to the '70.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-19-2010, 08:49 PM   #4
tnmssmonte
It actually has the front and rear diffs in it, just no engine, trans or transfer case. I have a 88' k5 with a 350tbi and 700r4 with the np203 transfer case. What would be needed to swap the drivetrain over? also someone had cut the engine cross member for some reason on the 70. Will the 88 k5 driveshafts fit or will they need to be cut down?
