Old 02-08-2003, 10:24 PM   #1
86SILVERADO
86SILVERADO's Avatar
It never ceases to amaze me....
What a simple tune-up can do.
I have been driving my 84 straight six around while I was installing the new 350 in my Silverado. It had been running a little rough but not to bad. A little hesitation on acceleration every once in a while, no big deal. The master cyl. was leaking so the other day I replaced the master cylinder and bled the system and went to start the thing up and wouldn't you know it. No start. Checked all vacuum hoses and replaced a few, plugged egr, did fuel filter, blasted a pint of gas into a mason jar with a couple cranks of the engine (nothing wrong with fuel pump). There was a healthy stream of gas into the carb when I pushed on accelerator pump rod. I thought spark looked a little weak against the frame so I replaced the coil with a good one from another HEI unit I had that I knew was good. Still no go. the cap and rotor were good and I knew I would be wasting money on a new set, Sooo... I did the plugs and wires and it fired right up. I have this uncle who I (used to) call for advice when ever I had some wierd problem that I couldn't figure out and his advice was, more often than not, "give it a tune up".
Some people never learn....
86SILVERADO is offline   Reply With Quote
Old 02-09-2003, 01:24 PM   #2
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Probably fouled the plugs. The 307 that came with my truck had such bad compression that the plugs would foul on a regular basis. The cold weather starts made it even more unbearable.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
