Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 04-19-2010, 11:33 PM   #1
Captainfab
60-66 Nut
D52 Caliper Rear Disc Brake Brackets
These are the latest rear disc brake brackets that I have designed with help from a few other members. These brackets will bolt onto the truck 12 bolt rear differentials from '64-'82 and the 10 bolt truck differentials from '79-'87. The OEM application for the rotors used is the '92-'02 AWD Astro/Safari vans. These have the 5 on 5" bolt pattern the same as the '71 and up C10's are 11.6" in diameter and 1.29" thick. The brackets will accomodate the OEM 'D52' size calipers as well as the new Wilwood dual piston D52 calipers. The D52's can be identified as the large GM calipers with the 7.06" center to center of the mounting bolts/pins.
The price on these is $257.00 plus a flat rate shipping of $16.25 anywhere in the USA. These brackets are also available powder coated in satin black for an additional $28.00 This pricing is always current and up to date. If you are outside of the USA contact me for a shipping price. What is included for this price is shown in the first pic, which includes the 3 piece assembly for both sides, plus all the necessary grade 8 hardware for mounting to your differential.
For payment I accept PayPal and money orders. If you would like a set, post in this thread and or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
A big thanks to smashingchuck for contacting me and supplying the Wilwood D52 dual piston caliper. And thanks also to lolife99 for contacting me also and the encouragement.
Last edited by Captainfab; 10-08-2021 at 09:38 PM. Reason: Shipping price increase
Old 04-19-2010, 11:45 PM   #2
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
Here are a few pics of the OEM D52 calipers. These are available in two different piston sizes. The JD5/JB5 calipers have a 2 15/16" diameter piston and the JD7/JB7 calipers have a 3 5/32" diameter piston. If you need a E-brake these can be found under the application of rear calipers for the '76-'78 Cadillac Eldorado. The A1 Cardone part numbers for these are 16-4116 and 16-4117. Those are loaded calipers.
Old 03-14-2011, 12:52 AM   #3
67chevy1series
67chevy1series's Avatar
that right there is what i want on my truck the 76 78 eddorado calipers with e brake cables so i need these brackets in order to fit the caddilac calipers right? once agian rewally sorry for how man questions i am askin
67chevy1series is offline   Reply With Quote
Old 03-14-2011, 01:00 AM   #4
Captainfab
60-66 Nut
Yes these are the brackets you need to use the '76-'78 Eldorado calipers
Old 10-01-2018, 06:28 PM   #5
M.A.C.'sFAB
I'm currently working on converting my rear to disc on my '70. Can these brackets also be used when keeping the 6 lug pattern?
Planned on using 1990 K1500 w/ f44 (heavy duty) chassis 6 lug rotors (11.6 dia. and 1.29 thick) and using 71-72 front calipers in the rear. Any foreseen issues I may have? Besides some possible machining...
M.A.C.'sFAB is offline   Reply With Quote
Old 10-02-2018, 12:14 AM   #6
Captainfab
60-66 Nut
You can not just randomly change the rotor and still have the rotor and caliper line up. I have yet to find any two factory replacement rotors for different applications be exactly the same and interchangeable. I have no idea what the height is of the rotor you are wanting to use. Then there is the issue that most later model rotors do not have sufficient contact area to accommodate the D52 pads without having them hang over the outside edge.
You know that I do make 2 rear disc brackets for the 6 lug correct?
http://www.67-72chevytrucks.com/vboa...d.php?t=637489
http://www.67-72chevytrucks.com/vboa...d.php?t=494411
Old 10-02-2018, 12:10 PM   #7
M.A.C.'sFAB
Right, I do know that. The rotor overall height is 2.6"
My intention is to keep the front brakes the same as the rear, by using the same caliper. They have a larger piston then most and are cheap to replace.
I was just wondering if you had a set of brackets that would work for my app?
Old 10-02-2018, 11:56 PM   #8
Captainfab
60-66 Nut
The Astro/Safari rotors are 3.27" tall. That is a difference of .670. I don't know if a .625" thick spacer would work. It might require a .750" thick spacer machined down to .670". It seems like I tried to use the F44 rotor when I developed my 6 lug kits, but I couldn't get the D52 pads to fit, like I mentioned previously. I would have to go back and look.
Old 04-20-2010, 12:23 AM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Got my set of powdercoated brackets today!
Super nice product, with great customer service.
Highly recommend these as a lower cost alternative to rear disc brake kits,... and the ability to use factory oem parts.
A+ to Captainfab for designing these brackets!
Keith
Convert to disc brakes.
Old 04-20-2010, 06:33 PM   #10
jkb
Wow great job! Great price too! I bet we wish we all had a lil of the Captians skill in us
"All Alone Meet & Greet 2010."
http://67-72chevytrucks.com/vboard/s...d.php?t=393754
jkb is offline   Reply With Quote
Old 04-22-2010, 09:41 PM   #11
Nova_Cobra64
Nova_Cobra64's Avatar
If you don't mind me asking, is there a distinct advantage to this setup versus the camaro/impala setup you offer? Parts/aftermarket availibility?
I am planning on doing one of these conversions in the future, I just have to learn about my options and then consider which route I want to go.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 04-22-2010, 11:09 PM   #12
Captainfab
60-66 Nut
Well this whole disc brake bracket assembly came about as the result of a couple members wanting an affordable rear disc brake conversion that would accept the Wilwood dual piston D52 calipers. As is works out the GM D52 calipers will work as well, which can be bought for around $15.00 each for rebuilt calipers, not counting the core charge. A lot of guys will have a couple D52 calipers laying around that can be turned in for cores. So from that perspective the calipers for these can be very inexpensive if you don't need an e-brake. If you do need an e-brake, those will run about $110.00 plus a core charge of around $25.00. The GM D52 calipers come in 2 piston sizes, 2 15/16" and 3 5/32" whereas the Impala, and the Camaro calipers are considerably smaller at 1.59" for the Camaro caliper and the Impala SS calipers at 2.13".
The one other thing that I like about this setup, is the rotors. The Astro rotors are about the same diameter as the Impala SS rotors, but the Astro rotors are 1.29" thick compared to the Impala SS rotors which are .790 thick. I just like the thicker, heavier rotors, plus they are the same thickness as most front rotors.
I haven't done a total conversion cost comparison between the three assemblies, but I feel that these are a little better suited for use on a pickup. The brackets themselves are more expensive than either the Impala brackets or the Camaro brackets, but I believe that a person can do the conversion for less money overall. Plus you can always upgrade to the Wilwood dual piston D52 calipers at a later date without any modifications.
A lot of what makes either one better for you, is if you can source any of the parts needed for one more economically than the other. And also what you expect fron your truck's brakes.
Old 04-25-2010, 12:58 AM   #13
Captainfab
60-66 Nut
Here's a pic of the brackets in satin black powder coat.
Old 04-25-2010, 01:56 AM   #14
toms84ss
Couple of questions for you Captain. Are the rotors from the front or rear? And what will we find the GM "D52" calipers on?
toms84ss is offline   Reply With Quote
Old 04-25-2010, 05:17 PM   #15
cpetersen
cpetersen's Avatar
I believe these are D52 calipers? With these calipers and rotors off of the astro van they will work with 15" Wheels won't they?Name:  DSC00380.jpg
cpetersen is offline   Reply With Quote
Old 04-26-2010, 12:00 AM   #16
Captainfab
60-66 Nut
As N2TRUX posted, the D52 calipers are found on the front of most full sized cars as well as the C10 and C20 trucks from '71-'87. The rotors are front rotors since the Astro vans didn't come with 4 wheel discs. At least that I know of. The application for rotor that I used was 1992-2002 AWD Astro/Safari van
Those are the Eldorado D52 calipers with the built in e-brake. Those are the ones you would use if you need an e-brake on this conversion. If you turn those in as cores, make sure you keep the e-brake levers. As far as I know you cannot buy replacements for them. And yes you can use 15" wheels as long as they are disc brake compatable.
Originally Posted by cpetersen View Post
I believe these are D52 calipers? With these calipers and rotors off of the astro van they will work with 15" Wheels won't they?Attachment 576917
Old 04-27-2010, 12:31 AM   #17
cpetersen
cpetersen's Avatar
I paid $50 a piece for those oem 76 caddie calipers, what i can't believe they are getting $40.00 a piece for the the e-brake. Core charge at NAPA is $66.00 for the calipers. $87.00 for the reman calipers.
Old 04-27-2010, 08:22 PM   #18
csbatey
csbatey's Avatar
do you have to run a proportion valve! thanks
bagged 87
csbatey is offline   Reply With Quote
Old 10-27-2010, 02:22 AM   #19
shiner2001
shiner2001's Avatar
If I were to buy new calipers from the parts store, does that mean that they will not come with everything needed to run an e-brake? Are there parts that will ultimately have to be found used or in a junkyard? I was planning on not running an e-brake, but it hadn't occurred to me that it was necessary for the state safety inspection, so I'll have to go with the Caddy calipers it looks like. Anyone had an experience with finding the Caddy calipers new with the e-brake setup? I don't actually think that for the safety inspection that they usually even check the e-brake, but I'd rather be safe than sorry and not be able to pass inspection sometime down the road.
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 10-27-2010, 11:55 PM   #20
Captainfab
60-66 Nut
I haven't bought the Eldorado calipers myself, but I have read that they don't come with the arms for the e-brake. Some guys have made their own using the correct size wrench. If you get a set of the Eldorado calipers and they don't come with the arms, and you can't get the issue solved, let me know and I'll get you taken care of.
BTW, your brackets shipped today. You should see them Saturday or Monday at the latest. Thanks again.
Old 12-04-2015, 07:52 PM   #21
LDO
LDO's Avatar
anyone have pictures of how the e-brake cables mount to these calipers and what cables to use?
LDO is offline   Reply With Quote
Old 04-25-2010, 05:55 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
The D52 is a front large bore caliper found on both cars and trucks from the late 60’s thru the early 90’s.
You can use the stock GM D52, or several aftermarket calipers that are designed to be a replacement for them. As mentioned Wilwood makes one with two different piston sizes.
Search Google for D52 caliper applications to get a more complete listing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-25-2010, 11:23 PM   #23
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks sick with the Wilwood calipers. Another top notch product! Great work Captain!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-26-2010, 08:04 PM   #24
shenk10
shenk10's Avatar
So just for clarification the rotors that are used with these brackets are '92-'02 Astro AWD Vans? I have the wilwood calipers up front, and was thinking about matching them up, so all I would need is this bracket, rotors, and the calipers if I'm correct? I wasn't planning on running an e-brake so I'm not worried about that. Thanks
shenk10 is offline   Reply With Quote
Old 04-26-2010, 10:49 PM   #25
Captainfab
60-66 Nut
That is correct. One other item that you will need is a couple of brake hoses. Some guys are happy with using the front hoses for the '71-'72 pickups. Others use hoses for a '79 Chevette. Or you can go with some aftermarket braided stainless hoses. I haven't looked to see what hoses Wilwood offers for their dual piston D52's.
