04-20-2010, 11:00 AM | #1 |
White Steel wheel paint code/Close enough spray can?
Hey,
Looking to freshen up a set of white steel wheels for my c-20 suburban. Does anyone have the paint code so I can order a some paint? Or is there a spray can available that is close enough? I also have some "clear" wheel paint from duplicolor I can spray over the top to keep the paint looking nice...anyone try it before? Thanks, Blake |
04-20-2010, 12:05 PM | #2 |
Re: White Steel wheel paint code/Close enough spray can?
Why not just go with a decent quality white spray paint? Way cheaper than getting a custom mixed white, and touch ups are only a Walmart away.
04-20-2010, 09:25 PM | #3 |
Hi Blake,
I went all out ... maybe even overkill with the wheels on dad's GMC. I stripped them down to bare steel, epoxy primed, and painted them with Nason Ful-Thane single stage urethane in GM #12 white. According to the old paint chip books I searched through, this shade of white was commonly used on GM trucks throughout the 70's and 80's as both a body/2-tone color and on wheels, bumpers, and such. You can likely get this color in a Dupli-Color or Plasti-Kote touch-up spray paint if you don't want to go to the added expense of a urethane paint. Last edited by ray_mcavoy; 04-20-2010 at 09:35 PM. |
04-21-2010, 06:57 AM | #4 |
Ray,
Those look great! I will get something like that in spray cans via some website. I plan on stripping them down also. Hope they turn out like yours! Did you use any sort of clear coat on them? opps....saw you said single stage..... Thanks, Blake Last edited by blakeduren; 04-21-2010 at 06:59 AM. |
04-21-2010, 09:47 AM | #5 |
IMHO, single stage W/catalyst is the best way to go for appearance and longevity, that said, I've had pretty good results using Rustolium "automotive" spray cans. Two coats and let bake a couple of days in the hot Florida sun. With no care at all, it holds up pretty well for a couple of years.
Today, I'm prepping the wheels on my 1 ton tow rig for a squirt of sunrise red. Not a real "bare metal" prep job, just a scuff and squirt to see if I like the red against the white cab and black flatbed, The rattle can gets the nod. RED |
04-25-2010, 02:16 PM | #6 | |
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
04-21-2010, 09:52 AM | #7 |
I used Duplicolor's White Engine Enamel and it worked out great. Using this also has an advantave since it has a ceramic coating in the paint, Brake dust wipes right off no scrubbing required.
1949 Five Window, 1973 Step Side, 2000 Z71 |
04-25-2010, 12:11 AM | #8 |
ENGINE ENAMEL!
Now, that is a great idea.... Thanks guys. |
04-25-2010, 12:43 PM | #9 |
Well, the fronts are done. Yep, that's red enough... now I gotta get the red "tonka" logo for the mud flaps, LOL. Paul.
