I put the laughter n slaughter
Hello fellas, long tim no post. So now that Im out of my financial slums, Ive gotten back to work on Ye Olde GMC. Im trying to get the lower control arm ball joints out. And brother, they aint coming.
I still dont care how you did it in California!!! ![]() |
Senior Enthusiast
Re: LCA Ball joints
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Re: LCA Ball joints
I used PB Blaster, and a BFH and they came out after a few wacks when the press wouldnt do the job. Watch those fingers.
UCA63
Re: LCA Ball joints
I used a short section of tubing a wee bit bigger than the ball joint to support the surrounding area underneath and a smaller (but longer) piece for the top side.
It kept everything square and localized the pressure to just the bj area. My press is only a small 20 ton and it worked great for this. PS I'm always on the lookout for short bits of tubing (the thicker wall the better) and solid bar to use with my press.And don't trust your chopsaw to make a sqaure cut,true them up on a lathe (I don't think a shop would charge too much,if anything) Hope this helps T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
Re: LCA Ball joints
Well, long story short... they come out alot easier if your pressing them out the right way <facepalm> Thanks for the suggestions anyhow. Got them out nicely once I was going out the right direction.
