What years do i need for donor
What years do i need for donor for my 66? 73 thur 87 or 86? i thought it was 87, but i looked at an 87 and the engine cross member is welded to the frame and i thought i heard it was bolt up or did that stop at 86? can i swap upper and lower a arms from 87 to my 66?
Re: What years do i need for donor
I was told 73-87 as well...
Shawn 1966 short fleet 230 I-6 three in the tree (daily driver) 1966 short fleet big block th400 (building slowly) 1972 c10 3 door suburban 350 th350 (building faster than slowly) 2004 F250 power stroke (not dependable enough to be a daily driver) 2005 Kenworth T-800 Heavy Haul tractor (that's my true daily driver) |
well i just looked at my 66 and no way will the 87 i looked at work as far as upper a arms. maybe the truck is a late 87 and they changed stuff
or do i just use everything but the 87 upper a arms. this 87 truck is complete, running with TBI 350, 4 speed auto, ps,pb,ac, disc brakes. all the goodies i want to swap into my plain drum brake 6 banger 66.
doesnt the whole cross member unbolt and drop out? If so take the whole enchilada, steering box and all...even get ahold of captain fab for one of his power brake booster brackets, and take that too...
the cross member looks welded to the frame and upper a arms are conected to the top of the frame
Senior Enthusiast
Here's the thread that has become the standard of information on front suspension and parts swaps:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#8 | |
wasnt 88 the start of the rounded body style..? If so you need the last of the square body's
60-66 Nut
That truck would be considered an '88
You could use the spindles, rotors, calipers, etc. on your truck. You would just need to change your C10 lower control arms for a set of C20 lower control arms. There are details in the thread than Markeb01 linked to. It's the one about converting to 6 lug disc's using factory parts. The spindles on the truck you're talking about are the same as long as they are 5 lug or thr 6 lug light duty 3/4 ton. But be aware that the rear ends on the '88 and up trucks are a bit wider than the '71-'87's and a lot wider than the '63-'70's.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-22-2010 at 12:37 AM. |
#11 | |
#12 | |
#13 | |
60-66 Nut
If you want to stay with the C20 8 lug, then you'd be better off finding a '71-'87 C20. On the '88 and up the spindles for the 8 lug hubs are different than the spindle for the 5 and 6 lug hubs. The 6 lug hubs are for the light duty 2500 (7300# GVW) whereas the 8 lug hubs are the standard duty 2500 (8500# GVW) And no the steering box from the '88 will not work on your truck. The '88 and up trucks have a much wider frame with the steering box on the inside of the frame. The '87 and earlier trucks have the steering box on the outside of the frame.
#14 | |
