Old 04-21-2010, 10:54 PM   #1
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Question 14bff and 15" rim questions
Im lookin for some 15" rims that will fit on a 14bolt. I have been told numerous different things from "you cant fit a 15" rim on a 14bolt, the drum ,wont clear, to you need 2 1/4" backspace....which is it? Please help. The 14bolt is out of a 77-78 1 ton. Drum brake, with the big hubs. I have 15" allied type 97's on the front in 6 lug, Im lookin for something similar in 8 lug, if not identical. Any suggestions?
Eturnit3 is offline   Reply With Quote
Old 04-22-2010, 02:45 AM   #2
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
Re: 14bff and 15" rim questions
never heard of anyone having a problem with a 15" on the rear, I know if you want to run 15" on a Dana 60 FRONT you need to grind the calipers abit.
I have a set of 15x10- 8 bolts, if it's not pissing rain in the morning I'll go out and see if they fit
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 04-22-2010, 08:06 AM   #3
b454rat
I had a set of 15" 8 lugs on my old 97 2500 HD (basically a 1 ton) with 4 1/4" offset wheels and they fit fine. Also had them on my old 89 GMC that I SAS'd that had the slip on drums, they were close but fit.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-22-2010, 09:18 PM   #4
Mike C
Mike C's Avatar
Eaton/Barts makes 'em. You can get them from National Tire Wholesalers, www.ntwonline.com
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-22-2010, 11:41 PM   #5
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
15x10 8 lugs all the way around, ground the calipers up front to clear the rims other than that bolt and go
Tex_50613 is offline   Reply With Quote
Old 04-23-2010, 06:22 AM   #6
LONGHAIR
I have never heard of an issue with 15" wheels fitting on a 14 bolt FF rear.
Fitting the front can be a bit problematic though.
I had 15s on the truck pic below, but they were two different brands of wheel. The rears were American Racing and because of the back-space, they would not fit the front. The wheels on the front were Jackman, which AFAIK are not even made anymore. The main thing was that they had less back-space...missing the calpiers and tie-rod ends.
Not the greatest pic, it is a scan from a snapshot from sometime in the summer of '82
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
