Old 04-22-2010, 09:25 PM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
LS swap questions
Is everyone that is running dual tanks having to use the 87 specific tank selector switch? Just wondering because I looked at both of them and they look identical. What is the difference between the two? Thanks
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-22-2010, 09:59 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: LS swap questions
probally reffering to the 87 fuel tank itself... there is a small baffle/bucket where the fuel pump sits into... the switches are probally the same as i cannot think of a reason why they would be different.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-22-2010, 10:03 PM   #3
STOCKISH
STOCKISH's Avatar
Nope, not talking about the tanks. I know those are baffled. I have had 87 tanks, senders, intank pumps , etc for months now. The 86 and older switch on the dash and the 87-91 switches are different. Just dont remember what is different about them.
--Josh
Old 04-23-2010, 08:53 AM   #4
Jonboy
Slots go on anything!
I think the later switch powers up the pump when it is switched (I think). Bob or Dennis will know, for sure.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-23-2010, 10:02 AM   #5
foamypirate
foamypirate's Avatar
When I was buying a new selector switch at Autozone, there were two styles. One was a momentary switch for L or R tanks that you held in place to switch the selector valve, then returns to a neutral position, and the other (the correct style for my TBI 87') stays in position for either L or R tank.
foamypirate is offline   Reply With Quote
Old 04-23-2010, 12:01 PM   #6
STOCKISH
STOCKISH's Avatar
I am just unsure which one I need for the LS swap. Bob or Dennis know?
--Josh
Old 04-23-2010, 12:07 PM   #7
nlped
nlped's Avatar
I would think that if you are using 2 seperate pumps, you would have to have the '87 up to maintain power to the f.i. pump.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-23-2010, 12:24 PM   #8
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Foamy and Jonboy have it right. There are two types, even in the 87. You want the one that is either in the R or L position. DO NOT get the one that says "Depress Fully".
NAPA usually stocks them, I had to replace mine. NAPA part number ECH FS502, $15.01.
This one:
NOT this one:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-23-2010, 03:30 PM   #9
STOCKISH
STOCKISH's Avatar
OK, I get it now. The relay for the fuel pump will run through the switch and send constant power to the pump chosen where the "depress fully" switch only sends power long enough to switch the valve.
--Josh
