Old 04-25-2010, 07:15 PM   #1
lks dcvn
lks dcvn's Avatar
Anybody get anything done this weekend?
It rained most of the weekend here so that would be a 'no' from me on getting anything done on the trucks.
How about you guys?
lks dcvn is offline   Reply With Quote
Old 04-25-2010, 07:27 PM   #2
Firebirdjones
Re: Anybody get anything done this weekend?
I got it washed and gassed up again so my wife can start another work week
Last weekend I did manage to finally get the lower fenders clear wrapped so we can off road without worrying about sandblasting the paint with rocks. Otherwise I'm done messing with the blazer unless something breaks for now, I spend most of my time working on the cars.
Firebirdjones is offline   Reply With Quote
Old 04-25-2010, 07:42 PM   #3
RickBost
RickBost's Avatar
I got the wife to give me my allowance so i can buy some parts for mine.. Now i just gotta figure out where to start.
72 GMC Jimmy 8" lift 38" super swampers
77 GMC C15 High Seirra Short Step lowered 6/8
http://67-72chevytrucks.com/vboard/s...53#post8999053
1972 Plymouth Roadrunner
2005 Cadillac Escalade
2014 Ram Ecodiesel
RickBost is offline   Reply With Quote
Old 04-25-2010, 07:44 PM   #4
swyfor5
swyfor5's Avatar
Nope, went trout fishing, caught 7 between 4 of us. I caught 5! Do have some new mirror parts due to arrive tomorrow, will post up some pic's asap!
swyfor5 is offline   Reply With Quote
Old 04-25-2010, 08:52 PM   #5
elks
Ordered some rear seat belts and spent the night supervising prom and after prom.
elks is offline   Reply With Quote
Old 04-25-2010, 09:40 PM   #6
AJs72K5
AJs72K5's Avatar
Me thinking about the truck was about as much as I got done. My son's 2nd bday was yesterday and the party was today.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 04-25-2010, 10:30 PM   #7
SeventyOne
Removed the engine and crossmember from the bare frame. Also removed the brake and fuel lines - working towards getting it ready to blast and powdercoat.
SeventyOne is offline   Reply With Quote
Old 04-25-2010, 11:33 PM   #8
bigdon-70blazer
Worked on weatherstrip installation on the top and about 70% of job getting carpet down on the front section of the blazer. Seats this week and I can't wait for you to see them, They look NEW! They look like brad new utility buckets with the original material. You are going to be amazed. The lady who did it followed the original patterns so well and so precisely. Can't wait to show you all.
bigdon-70blazer is offline   Reply With Quote
Old 04-25-2010, 11:57 PM   #9
frog trucker
frog trucker's Avatar
Location: Smack-dab in the middle of "The land of fruits and nuts", Sacramento, CA
I pulled the transmission out of my ‘68. I couldn’t adjust the clutch . . . every time I tried, it would just make a horrible racket. Turns out that the t/o bearing must have went dry and self-destructed.. . . destroyed the pressure plate with it! Lesson to be learned? Keep your freeplay adjusted!
Anyway, after reading my manuals, I was preparing to remove the bellhousing when I decided to try and get the clutch out through the bottom of the bellhousing. I felt very blessed when the p/p and disc was able to be wiggled out through the inspection cover. Probably saved me several hours! This week, I hope to install a Hurst floor shifter . . . my column shifter is shot.
frog trucker is offline   Reply With Quote
Old 04-26-2010, 09:45 AM   #10
Firebirdjones
I do clutch changes like that in our cars with 2 piece bell housings all the time. I don't even remove the trans entirely. Just remove the bolts and thread in long studs, then just slide the tranny back on the studs about 8-10 inches.
Remove the clutch through the cover, reinstall and slide tranny back into place. Sure saves alot of back breaking work
Old 04-26-2010, 12:24 AM   #11
AlaskaMatt
AlaskaMatt's Avatar
Swapped the engine mounts. It kicked my butt. Seriously it should have taken a couple of hours tops. But all day it was. One bolt had me swearing for 3 hours. Grrr..
AlaskaMatt is offline   Reply With Quote
Old 04-26-2010, 01:05 AM   #12
PHAT TONY
PHAT TONY's Avatar
I got the inside of my doors painted and hung for the final time(I hope!).
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 04-26-2010, 09:30 AM   #13
BigRed Beast
BigRed Beast's Avatar
Pulled the turn signal cancel springs off spare column and put them into the driver cam. Pulled the shift indicator and retainer off to clean. Serviced the KN air filter--nasty! Sanded and painted the sash channels. Ordered new rubber components for the doors on Thursday and--sigh--a factory assembly manual.
I'm the idiot who cannot manage to bring the kid's Blazer to a point where we can just block sand it and have it sprayed, so I've been painting it piece by piece with a foam roller, Rustoleum enamel and every grit of paper known to man. I have the donor doors on sawhorses and I've been working on them for most of the winter on the occasional warm day. It snowed (again) this weekend, so no progress other than above. A couple warm days and we'll have the top off, new/old doors on with emblems, mirrors, felt and rubber--maybe by next weekend!
Big Red Beast
1972 Blazer CST AC/Auto/4x4 "Project"
1997 F 350 CC Powerstroke "The Great White"
BigRed Beast is offline   Reply With Quote
Old 04-26-2010, 09:43 AM   #14
panhandler62
Java Mechanic
panhandler62's Avatar
Not much... I don't have an inside work area for big stuff. I had hoped to get the third member restored and remounted but all I was able to do was tap in the new pinion seal and clean/paint the pinion housing and yoke.
Watched Avatar (we don't go to theaters, so it was new to us) and races the rest of the weekend... lol
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 04-28-2010, 08:59 PM   #15
7D2N
7D2N's Avatar
Not this weekend but a few in the past. dang
7D2N is offline   Reply With Quote
Old 04-28-2010, 11:19 PM   #16
71jimmy
71jimmy's Avatar
Got my body mount brace and inner rocker on the driver side fitted, now I'm ready to sand and rust protect torsion box and under floor before tacking everything back in.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-28-2010, 11:32 PM   #17
Longblock
Longblock's Avatar
took the top off of it and drove the crap out of it.........
Longblock is offline   Reply With Quote
Old 04-29-2010, 12:02 AM   #18
BLUE THUNDER
BLUE THUNDER's Avatar
Cleaned my boat. Drove the Blazer
BLUE THUNDER is offline   Reply With Quote
Old 04-29-2010, 09:18 AM   #19
geemcee
geemcee's Avatar
Will be getting a new steel bed for my 71 GMC, also new cab corners and rockers. Painting very shortly!
geemcee is offline   Reply With Quote
Old 05-01-2010, 11:58 AM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I ordered new guages....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
