Old 04-27-2010, 03:03 PM   #1
Edmond
Edmond's Avatar
Dumb Question of the day: Carb & Intake
I'm sorry before hand if this might look like a dumb question of the day.
But will a Holley squarebore throttleplate fit on a Edelbrock Performer 2101 or do I need some adapter for it?
Thanks in advance.
Cya,
Edmond
Dutch Longhorn
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 04-27-2010, 05:36 PM   #2
Indyuke
Re: Dumb Question of the day:
I think the Edelbrock Performer 2101 is a spreadbore manifold, so you'll need an adapter. Someone will correct me if i'm wrong.
Indyuke is offline   Reply With Quote
Old 04-27-2010, 05:49 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
2101 is spreadbore... I have one under the Q-jet.
So yes, an adapter must be used with a squarebore Holley.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-27-2010, 06:19 PM   #4
Wrenchbender Ret
the performer manifold is set up to work either way' You do not need an adapter.
Wrenchbender Ret is offline   Reply With Quote
Old 04-27-2010, 08:46 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My mistake -- it's been quite a few years, but I thought the primary ports were small, to match the Q-jet.
Maybe that was just the stock iron manifold. Maybe it's just my bad memory.
- Mike -
RIP El Jay
Old 04-27-2010, 08:54 PM   #6
hugger6933
On some performer manifold If I recall EDELBROCK says that sometime a thicker gasket might be needed to prevent a vaccum leak. Jim
hugger6933 is offline   Reply With Quote
Old 04-27-2010, 08:55 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Wrenchbender is correct, it is dual drilled for either spreadbore or square bore carburetors so a Holley with bolt straight on.
However, the plenum opening is shaped for the spreadbore...
so you need to run one of these under any square bore carb on one of these manifolds, whether Holley, Edlebrock carb or what have you...
It's just an aluminum plate that Edelbrock sells for under 10 bucks that assures the gasket seals properly over in irregular plenum opening to assure no vacuum leaks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-28-2010, 09:09 AM   #8
Edmond
Edmond's Avatar
Thanks guys!
I think I'm going for the 2701 intake, no need for adapters at all.
Cya,
Edmond
Dutch Longhorn
The Netherlands
Old 04-28-2010, 09:23 AM   #9
msgross
msgross's Avatar
If the 2101 is already installed I would just get the cheap plate shown above, that's whay I did...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-28-2010, 09:56 AM   #10
Edmond
Edmond's Avatar
No there is no 2101 installed now so I'm just looking for which one to buy.
In that case the 2701 is the best option.
Thanks.
Cya,
Edmond
Dutch Longhorn
The Netherlands
