Old 04-28-2010, 08:24 PM   #1
73chevyman
73chevyman's Avatar
has anyone ever seen this done!!!!
Ok PO which was wifes stepfather lowered the truck old school.... the back he took out some leaf springs..... The front has got me totally confussed... i have pics of what I'm talking about but just don't look right.... take a look at these pics and if you can explain why this was done..........
this is the passenger side where the upper a-arm look at the rubber spacers??
Name:  100_1256 (Medium).jpg
driverside samething why was this done!!!!!
Name:  100_1258 (Medium).jpg
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-28-2010, 08:39 PM   #2
flatblkserria82
Re: has anyone ever seen this done!!!!
the shims is that what your talking about...? the shims are added and removed for caster camber adjustments, they had to put an ass load of shim because it had negative camber.
flatblkserria82 is offline   Reply With Quote
Old 04-28-2010, 08:40 PM   #3
flatblkserria82
oh and i'm pretty sure their metal shims
Old 04-28-2010, 08:52 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
They have nothing to do with the drop on the front other than re-aligning the front end, Looks like you will need to replace the upper control arm bushings soon too.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-28-2010, 09:00 PM   #5
73chevyman
73chevyman's Avatar
alot needs replacing but all the trucks i seen did not have this done... i think the way it was lowered has something to do with this it's crazy looking
73 C10 Fleetside
Old 04-28-2010, 09:03 PM   #6
Restrorob
Restrorob's Avatar
That's exactly right, When springs are cut or drop springs installed more shims are required to get the tires straight again.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 04-28-2010, 10:11 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Nothing crazy about it at all, it looks normal. Especially for a truck that was probably lowered in the front by either heating the coils or cutting a coil. Mine looks almost identical. The large round metal shims closest to the frame are normal.
The only thing that looks off to me is that they appear to be body shims instead of alignment shims.
This is my stock 91 Suburban, not lowered:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-28-2010, 09:52 PM   #8
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Thats why I stretched my upper a arms. It would have taken 1 3\16 worth of shims to get the camber close.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 04-28-2010, 10:11 PM   #9
f.monroe
f.monroe's Avatar
The 77 short bed I have has a Mr. Gasket part that they used back in theday . It bolts on where those shims are and extends the a-arm outward . The original owner lowered it in the late 70's when there were no spindles. He said they made that piece to fix the upper a-arms on lowered trucks . He also flipped the rear and added helper springs to keep it from bottoming out . Pretty cutting edge for the time it was modified.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-29-2010, 09:44 AM   #10
Stepsideride
Looks exactly like whats on my stepside...it was lowered with drop springs in the front and lowering shackles out back.
Stepsideride is offline   Reply With Quote
Old 04-29-2010, 10:03 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I am going to guess that it rode like a brick. What puzzles me is the fenderliner cut out.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-29-2010, 10:44 AM   #12
lax54650
that is what i first saw too ???
lax54650 is offline   Reply With Quote
Old 04-29-2010, 11:29 AM   #13
jchav62
1962 C-10
jchav62's Avatar
Mine's also shimmed. It's normal...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-29-2010, 03:15 PM   #14
73chevyman
73chevyman's Avatar
i don't know i need to put it back to stock height and start over and do it the right way
73 C10 Fleetside
Old 04-29-2010, 03:34 PM   #15
Prerunner1982
Prerunner1982's Avatar
My 82 with HD Coils (not lowered) was the same way..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
