04-29-2010, 01:05 PM | #1 |
Ball joint question..NEED help!
I am looking into some drop spindles,they are for an 88 C3500 and I want to put them on my '79 crewcab C30 dually. I called the manufacturer and they said the difference is the upper ball joint. Does anyone know where I can get the technical info/specs on the two ball joints?(88 C3500 vs 79 C30 dually) Thanks
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
04-29-2010, 02:16 PM | #2 |
Next project: 1970 K10
Re: Ball joint question..NEED help!
Oiy... the manufacturer of the spindle doesn't know?? I would think they would need the specs just to be able to make them. If not, NAPA might be able to help you.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-30-2010, 04:10 PM | #3 |
If you are saying '88 new body ('88-00), vs '79 then I don't think that I would take the chance.
But if it is for a square body, I would think they are the same?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
04-30-2010, 04:57 PM | #4 |
Insert Witty Text Here
Maybe they think that your '88 is the newer style, like an '88 half ton? I would look the balljoints on a parts store website and see if they are the same part number.
Slonaker |
