Old 04-30-2010, 04:47 PM   #1
Kalashnikov46
Kalashnikov46's Avatar
parking brake light
so recently my parking brake light has come on and decided to stay on. if i push my normal brake pedal down at about 3/4 of the travel the light will shut off and just a little past that come back on. thinking it was the parking brake switch i unplugged it, the light went away at first, but now its back on and there isnt any way the wire for the switch is grounding on anything, i taped the end.
-Bear
Here comes the devil doing 99...
facebook page thingy
Kalashnikov46 is offline   Reply With Quote
Old 04-30-2010, 05:00 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: parking brake light
Maybe it is telling you that there is a problem with your brakes, proportioning valve, or master cylinder? I'm not sure, but I think the "brake" light is used for more than just the parking brake.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-30-2010, 06:57 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
how is the fluid? does the brake pedal feel ok? does the truck pull when you step on the pedal?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-30-2010, 09:49 PM   #4
Kalashnikov46
fluid is ok. brake pedal has some free play, and it seems like i loose my power brakes alot. the right side rotor is kinda glazed so it pulls to the right under a hard stop.
-Bear
Old 04-30-2010, 11:33 PM   #5
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
The light is telling you that there's a problem that needs to be fixed. On my '78, everytime the light has gone on, it has been due to a faulty master cylinder.
78 Big10 454 is offline   Reply With Quote
Old 05-01-2010, 01:57 AM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Look at your prop-valve, You'll see another electrical connector there as well. That's your brake pressure sensor switch. If you've got little to no brake pressure, it'll cause your brake light to come on. I have seen very few prop valves fail, but have seen alot of M/C's go belly up. as well as power brake boosters.
My moneys on the Master Cylinder.
Replace it as well as your front brake pads & rotors (maybe resurface them if possible) and also replace your front caliper hardware. Be sure to lube up the caliper guides/slides well to help keep them from hanging up on you. I'm betting that's what was causing your truck to pull to that side initially.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 05-01-2010, 02:00 AM   #7
Matt Man
Matt Man's Avatar
I also had this problem, i checked the fluid and the back resevior was dry somethings wrong with your brakes.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-01-2010, 12:07 PM   #8
73chevyman
73chevyman's Avatar
i would check the rear cause the cylinders go bad and start leaking
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
