Old 04-30-2010, 05:45 PM   #1
Mike J
vw guy & now c-10 guy
Mike J's Avatar
speedometer cable
ok, another dumb question: my 68 doesnt have a speedometer cable installed and I dont see where it's supposed to go into the transmission. I wanna verify that the sender/gear thing is there before I order a cable. (dont want to pay for a cable then not have any place to connect it) It's a 68 250 with a 3-speed manual. anybody have a pic? thanks!
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 04-30-2010, 09:43 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: speedometer cable
ttt for you...
I have a 3 speed saginaw on mine. Someone probably sealed the cable opening and you need to insure you have the proper parts inside. I'll post a pic of mine with the cable installed tomorrow if no one has one they can post for you.
68gmsee is offline   Reply With Quote
Old 04-30-2010, 10:35 PM   #3
rusty baker
'70 C-10 Primer
rusty baker's Avatar
Long time since I worked on mine, but I think it's just below the shift arms.
"The difference between stupidity and genius
is that genius has its limits." Albert Einstein
rusty baker is offline   Reply With Quote
Old 04-30-2010, 10:41 PM   #4
Mike J
Mike J's Avatar
yeah, It has a aftermarket floor shifter in it and I found an old thread on here about one of the shift rods being in the way of the speedo cable with a floor shift- so the PO might have removed the speedo cable because of that...
'68 long fleet
My Build Thread
Old 04-30-2010, 10:45 PM   #5
rusty baker
'70 C-10 Primer
Mine has a cheap aftermarket shifter, too. Was on there when I got it. I hope you can get the right cable. There are several sizes of those plastic gears, and they aren't cheap.
Old 04-30-2010, 11:04 PM   #6
Mike J
Mike J's Avatar
can't understand why someone would drive around without a speedometer, but the last time the truck was tagged was in 1997, so who knows why the speedo cable isn't there? lol
'68 long fleet
My Build Thread
Old 04-30-2010, 11:19 PM   #7
msgross
msgross's Avatar
Those aftermarket floor shifters do get in the way... My 69 C-10 project kept breaking cables and needed a 90degree adapter. it should insert on the drivers side about 4-6 inches from the rear of the tranny IIRC.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-30-2010, 11:22 PM   #8
Mike J
Mike J's Avatar
cool, thanks, i'll check it out tomorrow- I wasnt aware they made a 90-degree adapter, that's pretty cool...
'68 long fleet
My Build Thread
Old 04-30-2010, 11:41 PM   #9
msgross
msgross's Avatar
might be abe to find them cheaper
http://www.transmissioncenter.net/sp...n_______va.htm
The Garage:
Old 05-01-2010, 11:19 AM   #10
68gmsee
Active Member
68gmsee's Avatar
Heres the pic in case you still need it. It's a good thing I took a pic. Looks like my cable is leaking.
Old 05-03-2010, 12:44 PM   #11
Mike J
Mike J's Avatar
thanks brother, I appreciate the pic! i'm gonna investigate tonight after work.
'68 long fleet
My Build Thread
Old 05-03-2010, 01:15 PM   #12
frog trucker
frog trucker's Avatar
Location: Smack-dab in the middle of "The land of fruits and nuts", Sacramento, CA
Hey Mike, we have a few things in common. . . I am working on my first C-10 after messing with VWs all my life. Last night, I put my Saginaw 3-spped on the workbench to ease the installation of a Hurst Indy floor shifter. I noticed that it allmost covers the speedo drive, but I am hoping that it will clear anyway. I will let you know. BTW, if you remove the speedo drive, you will leak gear oil, so have a pan under the trans!
frog trucker is offline   Reply With Quote
