Old 05-05-2010, 12:33 AM   #1
RustyDan
RustyDan's Avatar
Good HEI = Noisy stereo...Help !?
Well Thanks to the guys at this site, I fixed my HEI...Runs excellent.
So now I have poping in my stereo, And I know I need a noise filter of some sort. What have you guys tried that acually works the first time...???
"Do not follow where the path may lead.
Go instead where there is no path and leave a trail."
"SEMPER FI"
Never retired-Always a Marine
'72 C10 Longhorn-very daily
'86 C10 Van (mothballed)
previous; '65 C10 shorty
& bunches of M/C's
RustyDan is offline   Reply With Quote
Old 05-05-2010, 06:38 AM   #2
cdowns
cdowns's Avatar
Re: Good HEI = Noisy stereo...Help !?
i'd check to see if you've got good clean solid grounds on the stereo
Old 05-05-2010, 06:53 AM   #3
dznucks
dznucks's Avatar
I think there should be a filter in the internal or external regulator on your alternator. I could be wrong.
Mine used to do the same thing. every so often it would go to popping so bad i had to turn it off. Over time I replaced alot of factory grounds, with new grounds and cleaned up the rust and road grim from the mating surfaces too. i also upgraded to a bigger internally regulated alternator. The PO had done some shoddy wiring before me. So i removed alot of splices and wiring by replacing whole sections of the chopped up wiring harnesses.
I havent had the problems since.
Also, if you are running an amp, make sure your speaker wires are not close to your amp power wire. i have heard that could cause speaker noise.
dznucks is offline   Reply With Quote
Old 05-06-2010, 12:56 AM   #4
RustyDan
RustyDan's Avatar
cdowns your prob right.
Well so far it seems logical to climb under the dash...again, And check dem grounds.
dznucks...I have a local supplier for alternator goodies. I could build it anyway I need. I'm thinkin good call.
I'm 6'2" (in the morning) and 6'1" at nite.(gravity) So I guess I'll prymyself under the dash later in the day. LOL
Unless someone can give me some "cheat" solution for my slacker mood. Workin man blues you know.
"SEMPER FI"
& bunches of M/C's
Old 05-06-2010, 11:28 PM   #5
RustyDan
RustyDan's Avatar
Cleaned grounds, installed noise filter, secured 8mm tylers, (away from metal)
All is well I hear.
Stereo (hei caused poping) cured.
"SEMPER FI"
& bunches of M/C's
