Old 02-10-2003, 11:55 PM   #1
cped
Need Help with Frame Straitening
Working on 70 2WD SWB. Alignment shop couldn't align it stating the frame is bent. Passenger side wheel sits back in the wheel well (about 2") further than it should and it drives me nuts.
Can anyone out there offer suggestions, pointers, tips or help on how to get this corrected without having to drop a fist full of cash at a frame shop!?!?!?!?!?!?
Any help would be greatly appreciated.
Thanks,
Chad
Chad
cped is offline   Reply With Quote
Old 02-11-2003, 12:58 PM   #2
cped
BTTT
Chad
Old 02-11-2003, 01:07 PM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
You know it is the frame and not a control arm that is bent? Have you crawled underneath to see if you can tell what is bent and where? If it is your frame then I would guess it will be a fistfull of cash to fix. If your wheel is sitting back that far you should be able to see the damage on the frame or the crossmembers...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-11-2003, 06:57 PM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
I had my frame straightened when I first bought my truck. It was $250 well spent.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 02-11-2003, 07:20 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
I hit a stump in my 2wd one time and it pushed the lower a arm back a couple inches. I loosened the 2 u bolts that hold the a arm in place and hammered it foreward. Fixed!!
My k-5 blazer had a bent frame when i got it. I chained it between 3 trees and come-a-longed it out. Fixed!!
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-11-2003, 07:27 PM   #6
Rptsmngr1
frame straight?
you may want to try this method of checking your frame.on the opposite side or the good side select measuring points from the frame to the end of the control arms.measure both upper and lower control arms in the exact same locations.then measure the other side,compare measurements.this will tell you where the problem is,whether it's in your suspension or the frame itself.if you can try to collapse the coil spring on the bad side to relieve tension on the suspension.see if you can (wiggle) the wheel front to rear.this way you can see any extreme wear on the suspension components.other than obvious damage to your frame,you will have to take measurements to see if your frame has went "diamond".a good body man can help you out there.good luck!
Rptsmngr1 is offline   Reply With Quote
Old 02-11-2003, 07:55 PM   #7
cped
Thanks all for the suggestions.
Chad
Old 02-12-2003, 12:07 AM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
This is a bent frame!
I am talking to a shop in the Seattle area about straightening these rails. Hey, it's a SWB 4X4 and I have the title & vin...if I can just get these things right...
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 02-12-2003, 12:18 AM   #9
70cst10_05
70cst10_05's Avatar
nu uh quit lien that ain't a bent frame, haha, jk
kevin
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
