05-06-2010, 04:33 PM | #1 |
72 4 wheel disc
Ok I have disc on all four corners and am to the point of picking out a booster/master setup. My questions are should i stay with the original 9" or used a smaller 7" like some of the venders sell. I am not sure on the amount of vacuum that the engine makes so I'm kinda looking towards the 9". Also what about the proportioning valve, stock style made for disc/disc vs an adjustable one?
Thanks for any input!
72 Blazer 4x4 ZZ383 - Holley Stealth Ram - March Performance serpentine system - MSD (everything) - 700r4 - NP208 - 4.10 gears - Detroit True Trac - 295/70/17 Nitto on Mickey T's DC-1 wheels - and much more http://67-72chevytrucks.com/vboard/s...d.php?t=329193 |
05-07-2010, 09:36 AM | #2 |
Re: 72 4 wheel disc
Not sure what " it is but the 1Ton vacum booster is WAY stronger than a 1/2T & 3/4T booster.
P valve ~ some say don't need one on 4Wdisk..some say just put one adjustale on the rear and leave the front without...or also In-Line Tube sells a 4Wdisk Pvalve ~ right now I'm using a stock Pvalve on my 4wdisk but I think my brakes should be alot stronger as I run the 1Ton. So my next step is too by-pass the Pvalve and test it out. Mine is moastly off road so as long as I can stop I don't care if the back locks up first.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
05-07-2010, 10:39 AM | #3 |
Re: 72 4 wheel disc
Hydro Boost is the way to go. I,ve put it on two of my rigs, works awsome.
05-20-2010, 02:42 AM | #4 |
Re: 72 4 wheel disc
both are great my blazer has a 95 g cherokee booster and cilindor all y had to do make a bushing for the pedal linkage
cucharitas customs |
