05-08-2010, 02:25 PM | #1 |
Moving gas Tank
I want to move my gas tank out of the cab in the most efficient and lowest cost. Does anyone have suggestions? I've considered a blazer/suburban tank and neck. I can't find any used to use. I've also thought about a side mount tank such as extra tank such as one in LMC 1973 and up catalog. We're about to pull my cab and do repairs to the floor so now is the time.
I appreciate any help or comments. |
05-08-2010, 02:52 PM | #2 |
Grandpa in the rustmobile...
Re: Moving gas Tank
i gota blazer tank but had a wreck before I did the fiiller, its not hard to install the filler is the tricky part
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-08-2010, 10:26 PM | #3 |
Re: Moving gas Tank
The filler is one concern and I'm looking for the most cost efficient way to make it work. The blazer/Suburban tank is the cheapest so far besides the side tank. I am not real fond of the side tank for safety reasons. (if it sits outside the frame) The under floor tank the filler is where I am stumped. I've never done this before so I'm a novice.
05-08-2010, 10:31 PM | #4 |
Re: Moving gas Tank
probably cost wise id say a race fuel cell from summit, like 150 and then chop a hole in the floor for the filler bam few on heres done it they ought to show it
05-08-2010, 10:31 PM | #5 |
Re: Moving gas Tank
You can buy a poly blazer tank from lmc with mounting straps and sender IIRC.
As far as the filler, you can hide it behind the left side marker, in the bed floor, graft on a door to the bed side. I am putting mine behind the left taillamp like others have done before.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
05-09-2010, 11:04 AM | #6 |
Re: Moving gas Tank
I've found the tanks. Classic Parts is a few dollars cheaper. The filler is what I am not sure about using that tank. I am unsure about what to use and where to put it. Do you have any pics of what you're doing? What neck are you using to get it to the bedside. The previous owner got rid of the side marker lights. I don't really want to put it in the bed floor as so many do on wooden bed floors. I'm a novice at this part of it. can you tell?
Thanks for the information. Len |
05-09-2010, 11:06 AM | #7 |
Re: Moving gas Tank
Im not sure yet..
Ive got family in peroria, know any Hoffmans?
05-09-2010, 11:31 AM | #8 |
Re: Moving gas Tank
a cheap way is to measure the hole it's going to fit into then go to a swapmeet or junkyard with your dimensions and a tapemeasure
05-09-2010, 12:29 PM | #9 |
Re: Moving gas Tank
hmm good idea does aftermaerket not make one for a few bucks?
05-09-2010, 12:53 PM | #10 |
Re: Moving gas Tank
have seen gastanks for as little as $10 at swapmeets but none in a cataloges in that price range most were at least 10Xthat amt
