Old 05-10-2010, 12:35 PM   #1
truck-collector
how to determine what engine came in my truck
I just acquired a 1968 CST swb that had no engine in it. Unfortunately at one point the truck was repainted and the decal in the glove box was totally removed. Im trying to determine what engine the truck may have come with from the factory. Here is what I know:
It has the turbo 400 tranny.
It did come with a v8 per the vin.
It has factory air and power steering
It is a non posi rear end.
I mention these other items just incase one limits/narrows down the options. Id hope that it was a big block truck, but Im leaning towards the 327. Any where else I should look in the truck-any clues?? Thanks so much.
truck-collector is offline   Reply With Quote
Old 05-10-2010, 01:05 PM   #2
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: how to determine what engine came in my truck
Here are your options for 68.
In 1968, the 283 cu in (4.6 L) V8 was replaced with a 307 cu in (5 L) and a 310 hp (231 kW), 396 cu in (6.5 L) V8 was offered for the first time.
Does it have sbc motor mounts?
Maybe a different radiator for a 396?
Pretty hard to tell without the spid. Turbo 400 makes me think 396 but that could have been added by a PO. Not to mention these trucks could be ordered any way you wanted back then.
Congrats...post some pics
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 05-10-2010, 06:50 PM   #3
northerngmc
northerngmc's Avatar
So would the 396 in a C20 be different than a 396 in a C10? I thought my 396 L66 2 barrel was 265 hp
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-10-2010, 07:21 PM   #4
67/72junkie
High hump trans cover in floor bolts in for big block.BB cab will have heat sheild below ac box on lower firewall underhood or 2 holes where removed.BB mounts are shaped different but you can tell the difference at a glance.bb has about a 1'' diameter bolt hole in center and sb has 3/8 in center.
67/72junkie is offline   Reply With Quote
Old 05-10-2010, 08:04 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
Check to see if the engine stands are still on the frame. If they are take a pic. BB look like these sort of but have a larger hole in the center where the mount mounts, like someome said.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 05-10-2010, 08:28 PM   #6
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
U forgot the the 327 was also an option engine I have one to prove it . 307 was most common .
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 05-10-2010, 01:09 PM   #7
sameyrasmea72
Look for high hump cab floor, factory Exhaust hangers on both sides, were the engine mount stands left on the frame. These would give you some clues.
72 Cheyenne Super
Old 05-10-2010, 05:39 PM   #8
truck-collector
The frame mounts are still in the truck. What am I looking for?
Old 05-10-2010, 05:45 PM   #9
jbristo67
resident oilfield trash
jbristo67's Avatar
High up = big block
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-10-2010, 06:07 PM   #10
LMN8UR
LMN8UR's Avatar
Maybe you should take the opportunity to put in what you want in. Our trucks aren't rare, make it what you want! ! !
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 05-10-2010, 06:36 PM   #11
truck-collector
I know I can put whatever engine in it, but part of the fun of getting new stuff is figuring out what it is(was). What is meant between high up mounts? Any pictures.
Old 05-10-2010, 07:04 PM   #12
71swb4x4
71swb4x4's Avatar
Did you look for the build sheet? It should be under or behind the seat. It will be between the seat springs and the seat foam.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-10-2010, 08:37 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-10-2010, 08:41 PM   #14
truck-collector
My SPID is missing as mentioned above
Old 05-10-2010, 11:34 PM   #15
GASoline71
GASoline71's Avatar
LOL... I went back to your OP and noticed that you had no SPID right after I posted. I "deleted" my post. You musta saw it before I did that...
Gary
Old 05-10-2010, 09:15 PM   #16
307,327,or 396.The 396 had the dual exhaust and other mentioned items as well as a remote p/s reservoir mounted on the driver side fender.If it was a small block it will be hard to determine which.I`m trying to think of any differences in the engine compartment and coming up blank.I guess ithas the big radiator because of a/c?Maybe an a/c 307 didn`t?Never had one to know for sure.
Old 05-10-2010, 09:22 PM   #17
crites_72
crites_72's Avatar
my 68 had a 283 in it.
DJ
crites_72 is offline   Reply With Quote
Old 05-10-2010, 09:41 PM   #18
truck-collector
Thanks everyone. The mystery has been solved. I removed the carpet and the hump is non-removable. All signs point to small block which is fine for what I want to do with it. Now its on to buying parts...anyone have a complete set of side trim for a 68 cst swb?
