Old 05-13-2010, 01:31 PM   #1
Oklahoma
SBC #'s
Can anyone tell me what the #'s that are stamped on the front of the block indicate? I'm pretty sure that it is for the year/make/model/ect. but how do you know what they mean? I have looked everywhere for this informaton and have struck out, so I call out to all my fellow Chevy lovers for some info.
Thanks in advance.
Oklahoma is offline   Reply With Quote
Old 05-13-2010, 02:01 PM   #2
Southcity
Southcity's Avatar
Re: SBC #'s
You may find the below link helpful:
http://www.nastyz28.com/chevy-engine-code-stampings.php
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 05-13-2010, 04:48 PM   #3
Oklahoma
Re: SBC #'s
Yea I saw that site before and it helped me identify the block, heads, and crank, but unfortunately I have next to zero reading comprehension, so it is still a little foggy to me. I was hoping to find a site that I could just plug in the #'s and wham, bam, thank you mam, the magical answer would pop out. But hey thanks for helping out.
Old 05-13-2010, 10:01 PM   #4
Oklahoma
Re: SBC #'s
If anyone see's this the code I have on my block is TO725HC, I cant seem to find this code anywhere. Thanks
Old 05-13-2010, 10:05 PM   #5
brawley
Easy Does It
brawley's Avatar
Re: SBC #'s
try www.mortec.com
brawley is offline   Reply With Quote
Old 05-14-2010, 01:18 AM   #6
Captainfab
60-66 Nut
Re: SBC #'s
Here, scroll down this page to where you see the two HC's. It shows it to be either a 275 hp 327 or a 250 hp 350. I don't know just how accurate these listings are. It's been a while, but I'm pretty sure a couple 1965 300 hp 327's I had were the HC code. What heads are on the engine? casting numbers of both the block and heads might help narrow it down.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php
This site shows the same thing though...
http://www.73-87.com/chevy_ids/scode5.htm
Old 05-14-2010, 07:39 AM   #7
Oklahoma
Re: SBC #'s
Thanks guys, I always thought it was the first two or three letters on the stamping code that you used to look these up not the last. I know it is a 66 327 from the block, heads, and crank, just mostly wondering what the stamping indicated, like for each letter and each number.
stamp TO725HC
block 3803352
Heads 3782461
crank 4577
Thanks guys.
Old 05-14-2010, 03:07 PM   #8
NtheFamily
NtheFamily's Avatar
Re: SBC #'s
There should be another set of numbers/letters along with the ones you gave. Get those and let us know what they are. They should go similar to 17D198041. Those will tell you the exact month, year, plant and # off assymby plant. And yes, according to the number you posted it is a '65 327, originaly 275 HP or '69 350 with originaly 250 HP.
NtheFamily is offline   Reply With Quote
Old 05-14-2010, 03:58 PM   #9
Oklahoma
Re: SBC #'s
If there's another set of #'s I dont know where they are.
