Old 05-13-2010, 09:26 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
How easy is this frame horn to repair? Buying a collection.
I am buying a guys collection and this was one of his shotbeds. One of the other shortbed frames has had the frame horns are cut off. These are my two concerns about my the whole deal. There are two 69 SWB trucks one converted to 5 lug and one is a fleetside and one a stepside. There is also a seperate stepside bed. I will also be purchasing 5+doors, fenders cowls, a couple of hoods and 72 a/c cab, 90's bench all kinds of odds and ends, pullies, ram horns etc. One of the cabs may be too far gone. I forgot to get pics of the frame that was cut. Here are some pics.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-13-2010, 09:27 PM   #2
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: How easy is this frame horn to repair?
Here is some of the stash. I may also p/u a LWB bed.
Old 05-13-2010, 09:37 PM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
more
Old 05-13-2010, 09:41 PM   #4
burbguy
burbguy's Avatar
a little heat and a welder and your in business. Since the frame horns are forward of the front crossmember, then you shouldn't worry about any structural integrity being comprimised. Thats the great thing about steal, you can heat it bend it, cut it, bend it some more, fill in some missing spots, and weld it some more...
Shawn
1966 short fleet 230 I-6 three in the tree (daily driver)
1966 short fleet big block th400 (building slowly)
1972 c10 3 door suburban 350 th350 (building faster than slowly)
2004 F250 power stroke (not dependable enough to be a daily driver)
2005 Kenworth T-800 Heavy Haul tractor (that's my true daily driver)
burbguy is offline   Reply With Quote
Old 05-13-2010, 09:54 PM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Anyone know anything about putting a 90ish Caddy 5 on 5 lug disc rear end in these trucks? I can get one for practically free. Thanks for ya'lls help.
Kevin
Old 05-14-2010, 04:55 PM   #6
john
member #16
john's Avatar
Kevin
Heres a CPP tech on cadillac calipers on the rear.
http://www.classicperform.com/tech_a...kes-trucks.htm
john is offline   Reply With Quote
Old 05-14-2010, 01:00 PM   #7
OldCreek
OldCreek's Avatar
It looks like that passenger side frame horn has a crinkle all the way back towards the crossmember....I would worry about alignment problems after all is said and done.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 05-14-2010, 01:35 PM   #8
67/72junkie
same as above ,passenger side looks to have already been tried to straighten. bolt in cross member instead of rivot.you might be better off cutting that side off behind the crossmember and replacing.then you would only have 1 weld and a nice straight horn and radiator support mount.
67/72junkie is offline   Reply With Quote
