Old 05-13-2010, 11:11 PM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
rearend gears ?
how do you decide what gear ratio is best for one self dont know what my truck has and was just wondering how some of you guys decied
81ratrodc10 is offline   Reply With Quote
Old 05-14-2010, 07:43 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: rearend gears ?
I always start at 3.42:1.
Then, if you want more performance, go up numerically (ie, 3.73, 4.10, etc).
If you want more fuel economy, go down numerically (3.23, 3.08 etc).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-14-2010, 10:03 AM   #3
LONGHAIR
Re: rearend gears ?
It depends upon several factors. Tire size, transmission type, % of highway driving, intended use, etc.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-14-2010, 10:06 AM   #4
81ratrodc10
house of chevy's
Re: rearend gears ?
im not going to be running huge tires im looking into 275/60r15 drag radials th350 trans with stall converter average highway driving mostly my dd and weekend play truck
Old 05-14-2010, 10:07 AM   #5
blazer2007
Re: rearend gears ?
I used the Richmond gear calculater,just punch in tire size or gear ratio and it will tell you rpm at a certain speed or what you need to achieve rpm ,tire size etc.sorry I don,t know how to post a link but should be easy to find
blazer2007 is offline   Reply With Quote
Old 05-14-2010, 08:36 PM   #6
Mike C
Mike C's Avatar
Re: rearend gears ?
Great advice from all above. 275 60 15 are 28" tall. With TH700, would probably be happy with 3.73 or maybe even 4.10. With T350/400 would probably be better served with 3.42 or 3.73 on the big end. But it depends on the motor and what your intended use is as well. Plenty of gear ratio calculators out there to help you, start by figuring out what you have now to begin.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-14-2010, 09:42 PM   #7
81ratrodc10
house of chevy's
Re: rearend gears ?
how do i tell by looking at them what ratio it is
Old 05-14-2010, 09:53 PM   #8
81ratrodc10
house of chevy's
Re: rearend gears ?
buy the calculater is says i havr 2.08 does that sound right i know nothing about gears
Old 05-14-2010, 10:54 PM   #9
slugish
Slugish
Re: rearend gears ?
3.42 with a 3 speed 350 or 400 is the best of all worlds for you . Had a 3.73 in mine & took it out > then put in a 3.08 < ( good highway gear ) wasnt satisfied > ended up with A 3.42 . WITH A TALL TIRE 30 in or so a 3.73 would be ok .
slugish is offline   Reply With Quote
Old 05-15-2010, 09:24 AM   #10
LONGHAIR
Re: rearend gears ?
2.56 is the highest I have ever seen, you must have one of your input numbers wrong. Speedometer or tach readings may not be accurate?
Old 05-15-2010, 12:16 AM   #11
81ratrodc10
house of chevy's
Re: rearend gears ?
thats what i was told from a buddy of mine who has that ratio in his mustang
Old 05-15-2010, 01:27 AM   #12
3r!c84
Badass
3r!c84's Avatar
Re: rearend gears ?
i got 3.42 gears in mine with a th350 and 28in tall tires.it was a big improvement from the 2.7 somthings that where stock
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-15-2010, 04:25 PM   #13
dan76
Re: rearend gears ?
http://www.grimmjeeper.com/gears.html
This is a link to a road speed/gear ratio/trans type/rpm/tire size calculator. You can plug in different combinations and see the results.
dan76 is offline   Reply With Quote
