05-14-2010, 10:55 AM | #1 |
suspension lift
all i can find is 8" lift for my 69? is there any bigger lift kits out there? i have 43/4 ton axles off of a 74 and the whole drive train. i want to build a truck as big as i can. if anyone has found a bigger lift kit than that i would much appriciate some info thanks.
dave |
05-16-2010, 07:05 PM | #2 |
Re: suspension lift
Off the shelf? Probably not. The rear springs aren't the issue as GM used the same length springs on the rears up thru late 80's or so. However, the front length is unique to 67-72. Your best bet is to have some made by Alcan or Deaver. Expect to pay some $$$ though.
Keep in mind that it's not just adding taller springs. Brake lines and driveshafts will need to be lengthened. At those heights you'll also need to either add spring shims or move the perches to correct the huge pinion angle you'll have. You're steering geometry also changes considerably...drop pitman arms and draglinks, raised steering arms will be needed... This is by no means comprehensive, but you get the idea. Last edited by AJs72K5; 05-16-2010 at 07:08 PM. |
05-17-2010, 01:07 AM | #3 | |
Chevys Kick A$$
Re: suspension lift
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
05-17-2010, 12:40 PM | #4 |
Re: suspension lift
hey thanks for the input i called the places you said there about 350 a spring. when add it up plus all the other stuff i will need it's actually not to bad close to what i spent on my new truck and i will get 4 more inch's
thanks dave |
05-16-2010, 11:00 PM | #5 |
Future TOTM Winner
Re: suspension lift
I agree with AJ 100% Custom springs would be the way to go. Even if you found something bigger on the shelf the ride quality would most likely be horrendous. One of the custom springs he mentioned would give you the best springs possible especially at that height.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
