67-72 chevy c10 under a blazer 69
how hard would it be to swap out my frame which is a 1969 k5 blazer for a 2wd 67-72 frame?
SKINNY TIRES RULE!
Re: 67-72 chevy c10 under a blazer 69
Are you talking a PU frame? They are different wheel bases so you'd have to shorten the frame. The suspension from a 2wd PU will fit on the blazer with minor modifications and would be far easier than a frame swap. If you're planning on baggin it, you can go lower with a converted 4wd frame. Check out this article from sport truck magazine.
http://www.sporttruck.com/techarticl...ion/index.html
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
As bouncy said it's easier to convert a 4wd frame. The pickup frame is longer, and the body mounts are all wrong.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Yep its better to convertthen change the chasis the other chasis has diferent the curve where the box goes
