05-14-2010, 03:11 PM | #1 |
14x6 Vintage Torq Thrust on '72 with disk brakes?
I am curious if 14x6 vintage Torq Thrust wheels fit with the factory disk brakes on a '72? I have not yet looked to see if there is much clearance between the 15" wheel I have now. I am going to run a big/skinny set-up and don't mind the smaller wheels. I am not opposed to running a 1"-1.25" billet wheel spacer if that makes it work. Anyone have 14" wheels on your disk brake trucks?
05-14-2010, 03:14 PM | #2 |
Under Construction
Re: 14x6 Vintage Torq Thrust on '72 with disk brakes?
IIRC 15" is the smallest diameter rim that will work period.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
05-14-2010, 03:18 PM | #3 |
Insert Title Here
Ive seen alot of square body trucks on 13 inch wire wheels, so i dunno
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
05-14-2010, 04:28 PM | #4 | |||
"I ain't nobody, dork."
My 1972 Has 15X7 ET slots up front. I actually had to grind on the calipers and mounting flange toget them to clear. Gary
05-14-2010, 07:21 PM | #5 |
05-14-2010, 03:52 PM | #6 |
What is IIRC
05-14-2010, 03:56 PM | #7 |
Under Construction
If I Remember Correctly....
05-14-2010, 09:17 PM | #8 |
Its probally the bs i had some and pushed out away from the calipers the way the adapters worked
70 SWB STEPSIDE 70 BLAZER 09 challenger |
05-14-2010, 09:59 PM | #9 |
sharp as a marble
IIRC there are a bunch of aftermarket wheels that are configured correctly to accept disc brakes. I have done several conversions, and have done a few with 14" wheels. My bet is that the TT2's would clear the disc brakes.
11-13-2012, 05:00 PM | #10 |
I ended up going with original 14x6 ET V wheels with steel backs for more clearance & 1" spacers. Thanks for the help, forgot I started this thread but figured I would follow up with info.
11-28-2015, 05:55 PM | #11 |
do you remember what the back spacing is on you front wheels?
