Old 05-16-2010, 01:00 AM   #1
deadzero72
wont start dont know why!!!
i have a 72 chevy just changed the oil and transmission fluid. started before then right after the truck wouldnt start. the only thing that is different is the kickdown cable is gone. would that make it so the truck wont start? it has fuel and spark not sure what the problem is.
deadzero72 is offline   Reply With Quote
Old 05-16-2010, 09:37 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: wont start dont know why!!!
In my experience... three things that an engine needs to start:
Good fuel
Good ignition spark and proper timing of that spark.
Proper compression of the fuel.
Things that will prevent it from starting are:
The spark being redirected by moisture or cracks in the dist. cap.
Weak spark (coil)
Too much fuel- flooding.
Not enough fuel - filters or fuel pump. This is easily checked by squirting fuel into the carb throat.
Forgot to mention. WELCOME TO THE SITE!
68gmsee is offline   Reply With Quote
Old 05-16-2010, 09:46 AM   #3
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Something, probably simple, has been knocked-off.....unplugged....or something. There is abosolutely no way that changing your fluids will cause a motor to not start IF it was starting just fine before you did the service. retrace your steps very carefully and try to figure what else you might have done.
Just covering the bases. How do you know it has fuel and spark? What did you do to test each??
prostreetC-10 is offline   Reply With Quote
Old 05-16-2010, 12:36 PM   #4
mclairmo
That kickdown cable is near the distributor. Did you knock a coil wire or dist wire loose? Are you sure it was a kickdown cable you removed and not a throttle cable? 72 has a throttle cable.
mclairmo is offline   Reply With Quote
Old 05-17-2010, 01:14 AM   #5
deadzero72
i didnt use a pressure gauge but i undid the hose and it was spraying out. the fuel filter is dirty so i am going to get a new one. i put a spark plug to the block and it sparked. it also had compression. the throttle cable is intact and reactive. the only thing is the kickdown cable is not in the trans anymore but i dont understand why if it does affect it starting.
Old 05-17-2010, 01:38 AM   #6
El Jay
Gone to greener pastures
An inline fuel filter, or the one in the carburetor? A lot of times the filter on the fuel inlet gets overlooked.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-17-2010, 07:29 AM   #7
cdowns
cdowns's Avatar
if you have a quadrajet carb// the big nut on the carb body at the fuel inlet needs to b removed and inside theres a fuel filter
Old 05-17-2010, 11:04 AM   #8
tim21391
tim21391's Avatar
did the small power wire come off your distributor?.. maybe dumb but could you off knocked it outta time possibly without knowing it? maybe its too far advanced or retarded it just wont start no more... just my .02
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-17-2010, 01:36 PM   #9
deadzero72
inline fuel filter is dirty. i have a edelbrock carb not sure what kind just came with the truck but i will check all your guys' input.
Old 05-17-2010, 02:18 PM   #10
dznucks
dznucks's Avatar
Post us some pic's of your engine compartment. Specifically the dizzy area.
If you still havent solved the problem. I think you have inadvertantly knocked something loose.
dznucks is offline   Reply With Quote
Old 05-24-2010, 12:22 AM   #11
tim21391
tim21391's Avatar
maybe the moduler just happened to go out
