05-19-2010, 04:20 PM | #1 |
frontend
i'm fixing to get my 59 apache back soon and my question is about the frontend swap what is the cheap,eaziest way to do it i want to know what is the cheapiest eaziest ;middle of the road swap far as money and time and also about the swap kits you get through fatman etc i like that kind of swap but not the money and also the ride quality on different setups i would like to go with bags thanks jason
05-20-2010, 06:58 PM | #2 |
Re: frontend
ok if i was going to use a camaro front clip what years are best
05-20-2010, 09:11 PM | #3 |
Formerly- 1972SuperCheyenne
Re: frontend
Anybody?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
05-20-2010, 10:38 PM | #4 |
Re: frontend
as for the camaro year that would be 70-81, firebird is the same as well. I did the weld in cross member with tubular a-arms. Check out my "project 2 wheel drive" on down the page if you would like to see pix.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 05-20-2010 at 10:42 PM. |
05-21-2010, 08:59 PM | #5 |
Re: frontend
Another alternative is the 73-87 half ton IFS. It's a simple bolt on affair & should be an easy & inexpensive swap for you truck. I used one on my AD but had to have it narrowed to fit my frame. If I'm not mistaking your's being wider, it should bolt right up.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
05-22-2010, 05:17 AM | #6 | |
Re: frontend
