Western Drop Spindles
I got some Western spindles for a good deal today..Are they the same as CCP about using 71-87 brake components?
#2 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Western Drop Spindles
What year spindles did you buy? 63-70? 71-72? 73-87?
Redefining LowBudget
yes 71 -87 work but if you want to keep your 6 lugger than use a 92 2500 ( under 7300 GVW) disc..it all bolts on but you will need the covertion adjuster from CPP to adapt the pre 71 center link to the newer tie rod end
Im doing the same thing..took alot of homeowrk to find this out
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Western spindles are the spindles that you get from CPP. At least that's what I got with my kit. There are differences depending on year.
Moderator
![]() Join Date: May 2007
If you got Western spindles from CPP, they are the 71-72 type. The other years they sell are their own brand (stamped with CPP logo). I have them on my SWB truck and they fit like a glove, zero issues.
To answer your question, yes 71-87 disc brake stuff works, and you will need 71-72 ball joints and tie-rod ends.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-20-2010 at 10:43 PM. |
Moderator
Why is that?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
[B]I have to laugh when someone says somethings JUNK but has no reason as to why.
saying its junk seems to be enough ... ![]()
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Yes, that helped a lot. Thanks man
Ok since we're on this topic.
I have a 1966 swb that has 5lug disc. The PO said he "believed" it was all 72 C10 stuff. So I ordered drop spindles from CPP and they gave me part# CP4S3 Says theyre for 71-72 C10 Mine also say Western on the spindles. So am I to believe these will be a direct bolt-on to my truck? Since it already has disc brakes?
Tim Road Hounds |
Watch out for your cornhole !
![]() Join Date: Jun 2003
My CPP 73-87 spindles are Western brand too. Straight out of the CPP box...
hey Tex ,
what rubber line did you use to your calipers??and what adjuster it looks like a stock part?? one thing I have learned is to buy just the spindles and tie rod adjusters.....the rest of the parts you can usually get locally..this saves a ton in shipping.....my thought was if something ever happens to a disc like it warped or something do I have to go back to my vender to get the disc...these spindle makers don't make the discs,calipers or pads,they use off the shelf parts then re$ell them to us...a good parts man wll find out what it is...like I said for the 6 lug pattern the 1992 chevy 2500 ( under 7300lbs) discs are the ticket about $60 at Napa (and no shipping) it also cure the use of modern wheels up front but I'm not sure about how they fit on the rear axle since I'm using stock 6 lug rallies all the way around
#13 | |
#14 | |
Moderator
![]() OP- I would take one of the spindles to a parts house and check to see which year tie rod ends/ball joints fit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-22-2010 at 03:10 AM. |
#15 |
I beleive 73-87 tie rods and ball joints
#16 |
Hotrucks, every single inch of brake lines on my truck are unaltered stock 80 model stuff. It's all 100 percent bolt on from the master
cylinder to the wheels. The hoses are braided stock 73-87 hoses from Summit, Russell brand.
#17 |
thanx Tex..what about the tie rod adjuster??
Scotti I brought my spindles (western) and 5 lug discs that came with it to Napa (Lee) he took all the measurements and came up with the 92 2500 under 7300lbs ( keep in mind the 3/4 ton model is diff than the others) he grabbed one off the shelf and we slid it on...sized it up every which way..it was exactly the same except it was 6 lug
#18 | |
#19 |
Thanks for all the responses, now all I need is time to work on the truck. I work for Budweiser in Nashville and we lost our building and a half a million cases of beer in the flood we had here a couple of weeks ago , so we have been working around the clock to get back to normal.
Spraybomb, why didnt you like your spindles? |
#20 |
Sorry but what is CPP?
#21 |
Classic Performance Products http://www.classicperform.com/
Harrol 1968 SWB 1968 SWB 4x4 1969 Suburban 1970 LWB 1970 Blazer 2002 Tahoe Inside every older person is a younger person wondering what happened |
#22 | |
1968 LWB C20 / AC / Wood Bed |
#23 |
![]() Join Date: Oct 2009
Wow, that explains some things. I got my drop spindles from CPP and they were Western. They were supposed to use 73-87 rotors, which I purchased local from Napa. However, the rotors don't seem to fit right. Maybe they are supposed to be early model ? had a really hard time with tie rod ends also. Even called CPP to inquire if I had the right spindles and was told yes. Hmmmm...
#24 |
sea foam if your staying 6 lug you need the 92 2500 disc but it needs to be the under 7300lb version..
but I thoght the tie rods where 73/87..what did you find?? |
#25 |
Grandpa in the rustmobile...
hey project1968 where did you get your spindles...i saw some western boxes at goodguys today shoulda asked about em..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
