Old 05-21-2010, 12:08 AM   #1
jess66chevy
jess66chevy's Avatar
Question Spin on Oil Adapter kit??
Guys help me out here,
So I want to convert to a spin on filter. Here is the kit. Lets see if Im doing this the correct way. I am posting pics in steps. Correct me if Im wrong please.
jess66chevy is offline   Reply With Quote
Old 05-21-2010, 12:09 AM   #2
jess66chevy
Re: Spin on Oil Adapter kit??
Step 1:
adapter with nipple....
Old 05-21-2010, 12:12 AM   #3
jess66chevy
Step 2:
Adapter with felt washer
Old 05-21-2010, 12:15 AM   #4
jess66chevy
Step 3:
Bypass assembly on top of adapter with felt washer. (without O ring seal)
Old 05-21-2010, 12:16 AM   #5
jess66chevy
Step 4:
Assembly with O ring seal
Old 05-21-2010, 12:46 AM   #6
Captainfab
60-66 Nut
The ones I've used (years ago) were not supposed to be used with the original bypass assembly. Is this what the installation instructions say to do?
Old 05-21-2010, 09:17 AM   #7
DPowers
One foot in front of the other
DPowers's Avatar
I think the one he is using calls for the original bypass.
Link here:
http://www.secondchancegarage.com/public/509.cfm
DPowers is offline   Reply With Quote
Old 05-22-2010, 12:53 AM   #8
Captainfab
60-66 Nut
That does look like what the OP has. That does look like a good setup, better than what I've used before.
Link here:
Old 05-21-2010, 11:30 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
That looks like a quality design. Personally, I'd be very reluctant to ever use a spin on adapter again. Back in the 70's I had one fracture for no apparent reason, dropping the filter on the freeway which in turn wiped out the crank.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-21-2010, 11:31 PM   #10
msgross
msgross's Avatar
I tried the Mr Gasket one and couldn't get it to seal... WHAT A MESS!
went back to the canister.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-22-2010, 12:19 AM   #11
Slow Build
Slow Build's Avatar
My 283's casting # identifies it as 1957-66. So I'm guessing since it has a spin on filter that it has an adapter kit on it. I'll have to give it a good inspection when I change my oil tomorrow. My rear main seal is leaking so there is some oil back there anyway so a leak at the filter could be hidden.
For those running a kit, what filter are you running?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 05-22-2010, 04:06 AM   #12
LILRED66
LILRED66's Avatar
We have used them on a number of our truck projects and "knock on wood", no problems. We run Wix filters on all our stuff.
LILRED66 is offline   Reply With Quote
Old 05-22-2010, 07:52 AM   #13
msgross
msgross's Avatar
don't they require a Ford filter? seriously, some do...
The Garage:
Old 05-22-2010, 10:06 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
The type I had used a standard Ford filter.
Old 05-23-2010, 04:09 PM   #15
Slow Build
Slow Build's Avatar
Mine appears to be the Fram HPK1 adapter. Can't tell you how well it seals right now since my rear main seal is leaking so bad right now it's hard to tell if there is another leak. According to the page below I'm running the wrong filter. I bought the same filter I pulled off (Fram PH8A). The only difference I see on their website is the PH8A has an outboard gasket and the PH1 & 3 have indoard gasket.
Past GM Trucks:
Old 05-23-2010, 05:29 PM   #16
Slow Build
Slow Build's Avatar
Well the good news is I don't think my rear main seal is leaking. It's the adapter. Go figure. It looks like it's leaking around the outer lip where it meets the block. Now I just have to figure out how to fix it. I might go back to the canister filter setup. What parts do I need to get to go back? I know I need the canister itself but would I need anything that might have been taken out to put on the adapter?
Past GM Trucks:
Old 05-23-2010, 11:11 PM   #17
Rich 5150 69
Rich 5150 69's Avatar
I would look at the sealing ring underneath the adapter first before you change back. Maybe it just needs tightening up.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-24-2010, 09:36 PM   #18
Slow Build
Slow Build's Avatar
There I go making assumptions again. It actually says HP1 & HP3, which if I had read the page before on there website, is the PH8A, PH16 and PH43. My bad.
I actually upgraded slightly to the TG8A.
Past GM Trucks:
Old 05-24-2010, 05:20 PM   #19
raycow
The first spin-on conversions were released before Chevy V-8s offered a spin-on from the factory. As the Ford spin-on had been available since about 1957 and was easy to find in the replacement market, that's what the early conversions used. When the Chevy filter (outboard gasket) became available, some makers redesigned their adaptors to use it, but others continued with the Ford filter because it worked perfectly well.
Further complicating matters, some GM engines other than Chevy used a spin-on (I believe the original AC number was PF-7) which looked similar to the Ford (inboard gasket), but had the same thread size as the Chevy filter. Since this one was also available before the Chevy, at least one conversion used it.
Ray
raycow is offline   Reply With Quote
Old 05-22-2010, 09:23 AM   #20
LILRED66
LILRED66's Avatar
I have never heard that or used one.
Old 05-22-2010, 10:02 PM   #21
DPowers
DPowers's Avatar
Looks like about the same adapter I used. I use the Napa Gold 2 quart
