http://public.fotki.com/street
fast turn signals
my turn signals flash real quick...a different flasher didnt seem to make a difference, any ideas??
Burnt Bulb ? that it????
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Old Skool Club
![]() Join Date: Jun 2001
Speed is controlled by load
The more of a load, as in more bulbs to be controlled by the flasher, will make a standard-duty flasher work harder. Like your heart, the more of a load it has, as in more weight on your body, the harder it has to work. A heavy electrical load causes the bi-metallic strip to heat more quickly and the flasher operates faster, which you see in short bursts of light. To help fix/prevent problems, you should buy a brush made specifically to clean your bulb sockets (make sure you turn all lights off, first). Then, you should consider going to (1) a heavy-duty flasher or (2) an electronic flasher. Electronic flashers are NOT dependant on load to control the rate of flash.
I know this is a lot of info, but maybe it will help you understand.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Feb 2000
I was having this problem with just the driver side going real fast - got a new flasher and it solved my problem. Now you can actually see the driver's side flash!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
