Old 05-27-2010, 04:43 PM   #1
bigeasycigars
bigeasycigars's Avatar
1971 K/5 Electronic Ignition Conversion?
What is the best HEI set up for my K/5? (350with an Edelbrock Performer 600 - 1406) . Wires, Distributor, Coil, Ignition Control, etc.. ?
Please advise..
bigeasycigars is offline   Reply With Quote
Old 05-27-2010, 05:04 PM   #2
drunkbus
New Member
drunkbus's Avatar
Re: 1971 K/5 Electronic Ignition Conversion?
I'm running the MSD digital E-curve and I like it. It's easy to hook up and the adjustable timing options are nice once you figure them out. You might as well throw out the instructions. Another feature that I like is the built in adjustable rev limiter. On these trucks firewall clearance can be an issue with the standard HEI with the big cap. This has a smaller cap for more clearance.
http://www.msdignition.com/2006/06-8.htm
drunkbus is offline   Reply With Quote
Old 05-27-2010, 08:34 PM   #3
Mike C
Mike C's Avatar
I have an MSD as well, but just the small cap ready-to-run distributor. No fire wall mods since it uses a small cap. Mine is an older version that uses a window cap like on the stock distributor.
http://www.summitracing.com/parts/MSD-8360/
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-28-2010, 05:34 PM   #4
cleszkie
cleszkie's Avatar
Mallory one-wire GM HEI with vacuum advance and 50,000 volt coil. It has the full size cap, but it seems to fit my truck with no rubbing on firewall (rubbing could be a problem if you have worn out body mounts, but nothin that a BFH and minor firewall massaging won't fix).
cleszkie is offline   Reply With Quote
Old 05-28-2010, 05:48 PM   #5
bigeasycigars
You have a body lift on your rig? I'm going to replace my body mounts rubber is the way to go ya think?
Old 05-28-2010, 05:51 PM   #6
RED72blazer
urban fourwheelin
RED72blazer's Avatar
yes, rubber all the way.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 05-28-2010, 05:51 PM   #7
RED72blazer
urban fourwheelin
I have worn out body mounts and a mallory hei. It's close but no rubbing or massaging
here is the one I am running
http://www.summitracing.com/parts/MAA-8548201C/
