Old 05-27-2010, 06:35 PM   #1
Piece of Work
Cultural Infidel
Piece of Work's Avatar
bed removal
Is it possible for 1 person to remove a short fleetside bed by themselves? What equipment would this require?
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 05-27-2010, 06:42 PM   #2
cdowns
cdowns's Avatar
Re: bed removal
engine hoist and imagination can lift the bed
Old 05-27-2010, 06:49 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Re: bed removal
I did mine by myself with my engine hoist and a couple ratchet straps. I lifted it up with the engine hoist at the back of the truck and just rolled it backwards after I picked it up high enough.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-27-2010, 06:51 PM   #4
Papaloo
Papaloo's Avatar
Re: bed removal
I removed my LWB bed by myself, but I dissassembled the bed to do it. I removed the tailgate, disconnected the wiring and then used a impact gun to tighten all of the bolts holding the wheel wells in place until they broke. Once I had the wheel wells out of the way, I removed the bumper and bed mounting bolts so I could slide the bed away from the cab. Once the bed was away from the cab, I broke all the bolts holding the bedfront to the bed sides. I had to drill out the phillips bolts. I then broke all the bolts holding the bedside in place, with a couple of long bolts slipped through holes in strategic places so it wouldn't move until I was ready to pick it up and remove it from the bed floor. Once I removed the bedsides and bedfront, I flipped the floor off the side of the truck. Make sure when you lift any of the bed pieces, that you bend at the knees so you don't strain your back. They're all quite heavy.
Dave
1971 Chevy K10
1972 Chevy C10
Papaloo is offline   Reply With Quote
Old 05-27-2010, 07:09 PM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: bed removal
Go to the Florida forum and offer beers to all that show up.
Zoomin is offline   Reply With Quote
Old 05-27-2010, 07:10 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: bed removal
straps and a hoist...
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-27-2010, 07:30 PM   #7
tasian
tasian's Avatar
Re: bed removal
i removed my long bed by myself without a hoist....but it was late raining and i didn't really have a choice i wouldn't suggest it beer will always get you some help
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 05-27-2010, 07:34 PM   #8
colin_havens
colin_havens's Avatar
Re: bed removal
I pulled and installed mine with an engine hoist, some ratchet straps, and a 4x4 cut just long enough to fit under the bedrails. I have a pic somewhere, and will post it if I can find it. I will say having a friend to help steady the bed while I pulled the truck out from under it was a help. If you have about 3 other friends that can come over, you can pick it up and move it yourself.
colin_havens is offline   Reply With Quote
Old 05-27-2010, 07:50 PM   #9
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: bed removal
I got my bed lwb off by myself. I unbolted it from the frame then I put sawhorses at all 4 corners then lifted the front and propped it up with a chunk of 4x4, then slid a 2x12 plank across the sawhorses, then I repeated for the rear and drove out from under it. It was pretty rough, when I put it back on I got my cousin to come give me a hand.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-27-2010, 09:03 PM   #10
Shyguy
Junior Member
Shyguy's Avatar
Re: bed removal
I have used my 1950's Jubilee F#rd tractor and a boom pole before, but have decided to buy an engine hoist.
Since I am an old guy and work alone a lot a engine hoist should come in handy.
I have about got my small garage arranged so I can work on my trucks in it.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-28-2010, 08:20 AM   #11
custom70
custom70's Avatar
Re: bed removal
I removed my LWB by myself with a engine hoist and 4 x 4 under the rails, although it would be much easier if you had some help!
custom70 is offline   Reply With Quote
Old 05-28-2010, 11:47 AM   #12
Re: bed removal
Cherry picker and some wood and old bed frame
Palf70Step is online now   Reply With Quote
Old 05-28-2010, 12:20 PM   #13
hugger6933
Re: bed removal
two post lift with the arms on thr cross braces
hugger6933 is offline   Reply With Quote
Old 05-28-2010, 12:21 PM   #14
hugger6933
Re: bed removal
Also had enough muscle left over to hold the camera and drink a deit coke. ha ha. Jim
Old 05-28-2010, 01:50 PM   #15
Keith Seymore
Keith Seymore's Avatar
Re: bed removal
That looks a lot like what I did:
I made a wood frame for transporting it and for keeping it up off the ground while doing the bodywork:
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-29-2010, 12:48 AM   #16
pat 70/71
pat 70/71's Avatar
Re: bed removal
I made a metal fixture that fit under my short bed rails with little pads that fit up under the top flange of the bed with a ring welded @ the center for the cherry picker/ hook i , pushed it back& forth until it was balanced.It worked great still have it & used it many times by my self. Pat
pat 70/71 is offline   Reply With Quote
Old 05-29-2010, 03:25 AM   #17
domestictuner
Re: bed removal
i have something similar but use 2x4's underneath the top of the bedsides to disperse the weight
domestictuner is offline   Reply With Quote
