disc brakes for chevy 56 1/2 ton
How can be converted drums into disc brakes chevy 56 1/2 ton.
thanks |
Cancer Survivor in the making.
Re: disc brakes for chevy 56 1/2 ton
Pretty much any one of the old truck vendors offers at least one kit to do this on the front. You can choose either 6-lug or 5-lug. The kit is basically the same for '41 through '59.
You need to also convert to dual master at the same time and generally you'll need to replumb at least part of your brake system to make it work.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
You can buy complete kits or just the brackets and put it together with parts locally purchased. Most of the kits are for 15" wheels minumum
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Lmc has a kit.mbgmike where can you get just the brackets. What year rotor and calipers do you use.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#5 | |
If you want to run the larger (12 inch) rotors, I am pretty sure you will need aftermarket spindles. Ray Last edited by raycow; 05-28-2010 at 12:41 PM. |
#6 | |
Yes you need the bearing kit. Thast availible seperate also. |
#7 | |
We sell them. We sell all kinds of brake stuff for almost every vehicle.They are availible many places. from US, SPeedway motors, MPbrakes, and others usually less then $100.00 |
