05-28-2010, 12:59 PM | #1 |
Need help! Broken shock bolts!
So yesterday I was installing some new shocks and both of the lower shock bolts (in the LCA) snapped in half. The shock came out but now I have no way of bolting in the new one. Can you guys give me some options for fixing this? (without taking the whole LCA apart). This kind of thing is really why I hate working on my vehicles. I usually either strip, lose, or break the last nut, bolt, or screw ....
2008 NNBS ECSB Cocoa Metallic Texas Edition McGaughy's 5/7 Drop: 2" Drop Spindles, 2" Coil Relocators, 1" Drop Springs, 7" Flip Kit, 2050 Shocks, Shock Extenders, McGaughy's Helper Bags / 24x10 U2-55 wheels on Kumho 275/30/24's / DiabloSport Predator Diablo Tune / DDM Raptor HID's / Debadged / Lamin-Xed Headlights (Tint), Taillights (Gunsmoke) and Fog Lights (Tint) / Extang Tri-Fold Tonneau Cover My previous trucks: My '84 SWB My Tahoe Limited |
05-28-2010, 04:10 PM | #2 |
BMW & ASE Master Certified
Re: Need help! Broken shock bolts!
doesnt a regular bolt go through the LCA? its the one on the side of the frame thats special... why not just cut the old one out and get a grade 8?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
05-28-2010, 05:08 PM | #3 |
As in the below pictures the bolts go in from the bottom into square nuts welded to the LCA. It looks kinda easy to grind square nuts from this picture but my front end is all together, so no easy access...
05-29-2010, 08:01 AM | #4 |
Could you drill them out?
nickle and dime |
05-29-2010, 03:24 PM | #5 |
Yeah I ended up having to drill all 4 of them out. I couldn't get them straight either..but they came out eventually. Then I bought 4 new bolts and they actually screwed right in, and then I put bolts on the topside because I had drilled away some of they threads. It was a PITA but it worked... Thanks for the help.
