How much does a 1965 GMC weight
HI Everyone
I am restoring a 1965 GMC truck. I need to no how much does my truck weight. It is a 2wd short box. I need to no this information so i no where to adjust my 4 link supension. ![]() Thank You Clark |
1961 crewcab
Re: How much does a 1965 GMC weight
my 64 silver book says 4100-5000 for the 1/2 tons (dependant on engine and accessories), since its a shorty I am thinking 41-4400...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1961 crewcab
that makes sense...
tony, could you add the 3/4 ton, and 1 ton weights? if you can, I will put a link to this thread in the faqs section.
1961 crewcab
thanks, I put a link to this thread in the FAQ section.
1/2 ton, 2wd, short wheel base, fleetside truck published curb weight is 3,330 pounds...published payload range 700-1,550 pounds.
1/2 ton, 2wd, long wheel base, fleetside truck published curb weight is 3,435 pounds...published payload range 600-1,450 pounds. 1/2 ton, 4x4, short wheel base, fleetside truck published curb weight is 3,690 pounds...published payload range 1,150-1,800 pounds. 1/2 ton, 4x4, long wheel base, fleetside truck published curb weight is 3,855 pounds...published payload range 1,000-1,650 pounds. 1/2 ton, 2wd, short wheel base, stepside truck published curb weight is 3,300 pounds...published payload range 750-1,660 pounds. 1/2 ton, 2wd, long wheel base, stepside truck published curb weight is 3,390 pounds...published payload range 650-1,500 pounds. 1/2 ton, 4x4, short wheel base, stepside truck published curb weight is 3,660 pounds...published payload range 1,200-1,850 pounds. 1/2 ton, 4x4, long wheel base, stepside truck published curb weight is 3,805 pounds...published payload range 1,050-1,700 pounds. 3/4 ton, 2wd, long wheel base, stepside truck published curb weight is 3,830 pounds...published payload range 1,650-3,600 pounds. 3/4 ton, 2wd, long wheel base, fleetside truck published curb weight is 3,875 pounds...published payload range 1,600-3,550 pounds. 3/4 ton, 4x4, long wheel base, stepside truck published curb weight is 4,170 pounds...published payload range 1,550-3,400 pounds. 3/4 ton, 4x4, long wheel base, fleetside truck published curb weigth is 4,120 pounds...published payload range 1,500-3,350 pounds. Per the Truck Sales Data Book. The engine size & tranny type will change the curb weight, but this is the published information. Also, the amount of fuel in the truck will make the weight vary up to 160-165 pounds. Last edited by LILRED66; 06-02-2010 at 12:28 PM. |
#8 | |
I pity the fool with only 2 headlights! ![]() |
100% gearhead
My '63 LWB fleetside clocked in at 3715 in stock trim. I hope that is of some relavence!
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
Hey Watch this...
![]() Join Date: Sep 2007
My short step weighs just shy of 3600 with me in it, and 1/2 tank of fuel.
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
Just for reference my `64 chevy fleetside shortbed weighs in right at 3,800 lbs, on a truck scale with a full tank of gas, 350/350.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Thank you for all the information that you guys gave to me. This will help me alot.
Thank You Clark |
mine came in at 3890 its a 64 short bed
Who Me?
I weighted my 61 short fleet with a V8 TH350 and it came it at 3680. With me in it. Nothing in the bed, but I have a 1/8 steel floor.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#15 |
So 3300lbs is all my 65 swb stepside weighs hmmm .Well add a 350 vortec and Th-350 then add its 350hp engine (flywheel) plus I got 3.73 gears which should be a fun crusier red light action toy lol
Posted via Mobile Device |
#16 |
![]() Join Date: Oct 2012
I took a load of scrap steel in for sale. The empty weight of my 1965 C10 with 250 I6 (me off the scale) is 3460 lbs with 1/2 tank of gasoline.
#17 |
That's not as heavy as I thought they'd be.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#18 |
hey clark i just looked mine up the other day and i have a 65 gmc shortbox and it weighs 5000pds, ????? did you have rear leaf springs when u got it????
#19 |
5000lbs gross weight.
FWIW; my '65 C-30 SRW 9' step with a bunch of crap, me, and a bunch of "aftermarket" (lol) steel plate lining the bed (and over the fenders) rolled through @ 4,950lbs. I figured the empty weight as it is was about 4,600lbs. 283/SM420. Picture below. (Didn't have the sideboards when I weighed it.) I subtracted all the weight from the added stuff and IIRC I came up pretty much with what GM said it should weigh. ![]() |
#20 |
http://www.gmheritagecenter.com/gm-h...tion-kits.html
You can pull up the GM books for your trucks there and see what the base listed weight is. (Also shows options, etc. Neat site.) |
#21 |
Hey, that was a cool pdf. to look at. Why didn't they mention the 305v6? Was that only in gmc or something? I noticed it was only Chevy.
Live and let live ![]() |
#22 |
Yes, the 305 V6 was a GMC thing; I think some of the big V6's might have came (as an option) in some HD Chevrolet stuff IIRC, though.
