Old 06-02-2010, 02:30 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
Skip white Hei
I'm looking at getting this distributor for my '68 350: http://www.skipwhiteperformance.com/...px?Item=6500-R can anyone see any issues with it? I've heard only good things about skip white so I'm not worried about quality just want to make sure it's the right one for my truck.
thanks yall!
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 06-02-2010, 04:30 PM   #2
dznucks
dznucks's Avatar
Re: Skip white Hei
it'll work for your engine/tranny setup, i have the same as you. but you are getting what you pay for.
I went through three of them before going back to a regular HEI. it will run good for a while. i had the weight spring pins pull out or shear off of all of them. i also had the coil wires break loose. also remember that the extra 65K volts wont do you any good unless your electrical system can supply the extra power and the plug wires can deliver the power to the plug.
if you ever see your timing mark bouncing around, its more than likely that dizzy.
dznucks is offline   Reply With Quote
Old 06-04-2010, 12:42 AM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: Skip white Hei
The 6500-R you are looking at has a "...large flat Super [coil] cover..."
The 6501-R has an "...oem cover is tapered down on the top sides, and offers much more clearance..." (to the firewall--more of an issue on a 4x4 like in my potential application).
As of May 28 when I talked to them they were both the same price.
Here is an interesting thread in regard to quality: http://www.hotrodders.com/forum/hei-...on-178744.html
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
