Tire Sizes???
I just sold my worn out 33's and need to get some new tires. I was running them on a 12" wide weel with a 4" lift and didn't rub. Can I fit a 35" tire under my truck on the 12" wide wheel or will I need to narrow down to 10" wide? What are you guys with 4" of lift running for tires and what are your wheel width's?
I need another Barley Pop
Hey Slick, I know I'm not running the same size lift, wheels or tires, but here's what I have if it helps you to decide. I'm running a 35x14.5 tire mounted on 14" wide rims, 3 5/8" backspacing so they really stick out there. I have an 8" suspension lift and I can make my front tires rub. Hope this helps ..........
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() Last edited by Pont; 02-14-2003 at 07:40 PM. |
You can run a 35 with a 10" wheel, but most likely the 35 on the 12 will rub. For the most part I have no troubles with my 35's, but the do contact if you get it twisted up. And a little turning flat on the passenger side, but that is from an incorrectly executed body repair to the lower front of the pass. fender done sometime in the mid 70's.
SKINNY TIRES RULE!
I'm running 35 x12.5x15 w/ a 6" lift. I haven't had any rubbing issues (yet). My first Blazer had 35's and a 4" lift. I don't remember the exact tire size, but I think it was the same. I never took it off road so I couldn't tell you if it rubbed durning flex, but I had no problems on the street. I have heard of many people trimming the "Fang" off the of the wheel cuttout on the fenders to add more clearance for turning. How stiff is your lift? Also, different tire brands are different heights. I have heard that if your close to rubbing, avoid swampers or any tires with the big side lugs.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
