06-03-2010, 08:00 PM | #1 |
hei distibutor
Hi Guys, I have a accel dizzy in my 350 engine on my 1968 C10. I just picked up a msd hei cap and rotor from our local performace store, When i picked it the man said that my accel coil( 4003) would fit my new msd cap . Is this correct, The only reason I bought the msd cap was for the color ( red ). I didn't loke the brown accel cap. Will this set up work ?. I also bought taylor red hei spark plug wires. Thanks for the help Russ
06-03-2010, 10:39 PM | #2 |
Re: hei distibutor
i dont see why it would not fit but i dont really know procomp has a full distribitor with coil and a red cap for 60.00 or less
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
06-04-2010, 03:09 AM | #3 |
Re: hei distibutor
it should.. im running an accel distributor and i forgot to put the button in and it destroyed my cap and so i got a new one and figured id go with msd cap and rotor and i just used my accel coil.. and it fit just fine.. and ran just fine
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-04-2010, 09:03 AM | #4 |
Re: hei distibutor
Thanks guys, I like the red color of the cap. Tim i am doing the same thing as you did, thanks for the input....Russ
06-04-2010, 07:25 PM | #5 |
Re: hei distibutor
no problem. just dont overtighten your one coil screw going down to the ground little thing inside the clamp i stripped out and had to get another.. but ya it al lfits perfectly and runs same
06-05-2010, 02:11 PM | #6 |
Re: hei distibutor
Thanks for the update Tim, Russ
06-06-2010, 11:16 PM | #7 |
Re: hei distibutor
no problem
