06-03-2010, 09:15 PM | #1 |
Addicted to Rust
Ls Conversion guys, a quick ?
Does any one have a tow/haul mode without using the BCM? Apparently the BCM communicates with the PCM by serial data to make the mode in the trans change. Thanks Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
06-03-2010, 10:00 PM | #2 |
Re: Ls Conversion guys, a quick ?
not familiar with the term bcm.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Cherub; 06-03-2010 at 10:00 PM. |
06-03-2010, 10:19 PM | #3 |
Body control module
06' GMC 1500 Crew cab..... |
06-04-2010, 09:01 AM | #4 |
what year did they install them ive never heard of 1 my is a 2002
78 C-10 5.3 LSX -4L60E |
06-13-2010, 05:54 PM | #5 |
06-04-2010, 10:26 AM | #6 |
Ive seen that option in the tow package in a 99 01 and 06 that my family has. Its the switch on the end of the shift lever.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
06-04-2010, 10:28 PM | #7 |
Addicted to Rust
The BCM is the computer that controls "body" functions. It controls the dash display, the power windows, the AC actuators, all of the courtesy lights, power locks and keyless entry. It also sends out all of the tones like the seat belt buzzer lights on buzzer etc, it interfaces with the radio to do this and is probably the hub for the steering wheel radio controls.I am sure to have forgotten any number of additional functions. It communicates with the PCM by serial data on pin 58. If I could mimic the signal I could switch the trans modes. BCMs have been in GMs since the 90s and like the PCM have grown much more complicated. I originally was going to try to integrate a BCM to my 87, mainly for the factory keyless entry and the theater lighting, but it got fairly complicated real fast and in a hurry. Jay
06-07-2010, 11:39 PM | #8 | |
Pin 58 is a dianostic/flash serial data line shared by all modules. The BCM uses pin 59 (right next to pin 58) to communicate with the with the PCM. |
06-07-2010, 09:47 PM | #9 |
BMW & ASE Master Certified
nah, I wish they did, the LS1 computers uses a momentary ground... how convienent... Ive been hovering on HPtuners and no one has gotten it to work. I read that some guy was engeneering a pc board to get it to work, or he made one for himself. I think anoher peron tried to hook up just the bare necessities, power ground and the tow haul control and it didnt work. dont know why, but thats what i remember about that post. I wish there was something out there (cheap) that allowed us to run that feature.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
06-07-2010, 10:09 PM | #10 |
Anyone a GM electican tech??
it seems that you have to program this module if you replace it... would a junkyard one need to be programmed? and if it needed programming, could you program such a module to match a engine and trans wiring combo only? im not a gm tech, but i use to work at a chevy dealer so maybe the same electrician tech still works there and remembers me.. if so I might have to leave work and talk to him in person with a case of beer in one hand and a note pad in the other. From the transmission schematic, it looks as if the tow haul is just a momentary contact between ground and a pin on the bcm, and then the bcm makes its signal to the PCM. sounds easy enough but I swear I read someone had tried to wire the BCM up like I just described and it didnt work. If anyone has any BMW questions, Im your man GM BCM's not so much.. thanks
06-07-2010, 10:23 PM | #11 |
Addicted to Rust
I don't think its just a ground to the pcm. The pcm gets serial data on pin 59. Serial data from the bcm, I am not sure which other functions the bcm would turn on or off in the pcm? I used to be a GM tech and still have pretty food access to technical data.
06-07-2010, 10:41 PM | #12 |
06-08-2010, 12:45 AM | #13 |
thats the same schematic i seen in alldata. after reading some neat information about class2 j1850 vpw, it seems like power, ground to the module +
PCM C1 pin58 wired into BCM C1 pin a12 momentary swtich going from chassis ground to BCM C1 pin B12 BCM C2 pin A1 to PCM C1 pin 59 It should work if its programed. Thats what im unsure of. Since your PCM has a VIN number, I wonder if you could take the dealership a USED BCM and have them reflash it with your VIN number, but hooked up to a customers or stock truck and work? I also need to see if i can find a pinout of all wires of the BCM to find out what the other inputs are. If i had to guess, the inputs are all momentary grounds, but i would want to look at the schematics anyway. Taking a lsx truck to the dealer and having to explain to the advisor, hey I want you to program my BCM would be like telling an ape how to use tolite paper. Hopefully I can have some ducks in a row before I go bug the GM electrician.. clint edit: i wonder if HPtuners has a VCM control for tow/haul. if so, I want to activate it and see if the truck responds accordingly. It seems wierd how deleting the security thing from the pcm affects what it seens from the BCM...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 06-08-2010 at 12:53 AM. |
06-08-2010, 08:53 PM | #14 |
Addicted to Rust
Clinebarger you are right with the pin numbers. I was flying by memory and it just aint what it used to be. I will look into integrating a bcm after I finish the swap. I will probably source up one from the salvage and try to flash it the vin of the truck that the 5.3 came from.
06-08-2010, 09:52 PM | #15 |
so can you flash the bcm with the power, ground, and both class 2 wires hooked up?
06-08-2010, 11:28 PM | #16 |
so alldata doesnt have a complete pinout diagram of the BCM but it did give a power,ground and class2 diagram, when combined with the above schematic, I merged the 2 in MSPaint (see attachment). Man, althought I probally wont use the tow/haul option much... now that Ive invested all this brain work, I want to see if I can get it to work aswell. I wonder what it would take to program this sucker. I mean would the module fail if it cannot talk to the other modules that arnt connected. I work at BMW and modules fail on occasion while programming and it doesnt disable the car, that one module just doesnt work. We no longer have the option to program one module of our choosing, but it completly updates the car. GM is probally different.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 06-08-2010 at 11:34 PM. |
06-09-2010, 05:23 PM | #17 |
I started my original post created on 09/2008 on hptuners and it looks like the 0411 PCMs were used in vetts, ls1s and so on... so their mod was to change a calibration in the transmission table (i will take a look at the options tonight and post a screenshot if i can find it) and wire the momentary ground to pin 71 of the BLUE PCM connector. I still dont know how they figured that out becuase all of the diagrams I have found show pin 71 not used for truck and LS1's... genius I tell ya...
If it does have this option, Im going to be nervious about putting ground to that pin on my own computer. I have a spare 0411 PCM but it still will cost 100$ in HP credits... clint edit: Ive been told it should work, so Saturday or Sunday I am going to give it a whirl... High Hopes
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 06-09-2010 at 08:55 PM. |
06-09-2010, 11:33 PM | #18 | |
06-09-2010, 10:59 PM | #19 |
Addicted to Rust
Keep us informed. Jay
06-10-2010, 12:39 AM | #20 |
no prob,
http://www.hptuners.com/forum/showthread.php?t=19831 the guys that designed HPtuners is a genius....
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 06-10-2010 at 12:40 AM. |
06-10-2010, 11:30 PM | #21 | |
06-10-2010, 12:49 AM | #22 |
EFI Live > HPTuners :P
1972 GMC C10 |
06-11-2010, 11:04 PM | #23 |
dangit, i hit refresh and lost all of my post..
anyway, yeah to get the feature to work, its a custom tune. To get the swap to work anyway its a custom tune ... I recon some tuners go crazy but my settings feel great. I went with a well known reprutable tuner so I wouldnt have any issues. I only had to tweak the MPG setting on one of the tables... the thing huted for a gear becuase of the speed i was cruisng at.. no biggie at all. clint
06-13-2010, 01:51 PM | #24 |
Addicted to Rust
Yeah it is a custom tune, had to remove vats and the rear o2s. I had him turn the torque management down. I am going to install a transgo shift kit to take care of the shift firmness. Tow\Haul should be close to stock. Jay
06-13-2010, 08:44 PM | #25 |
Ive installed 2 transgo shift kits for the 4l60e.. pretty strait foward. when you pull the "plunger down" from the pump... if you cant get that sucker, drill a small hole and insert a screw and pull the screw down. the pliers sliped on the nub of the plunger and what part of the transmission my elbow hit, but it left a gash that forever to heal.
I borrowd HPtuners, modified the trans table, going to hook up a temporary ground switch to test it out tomarrow. clint
