06-04-2010, 01:02 AM | #1 |
swb 1 piece drive shaft f/s
it came out of swb 71 with a short tail 350 trans $50.00 or $72.00 shipped.
i have 67/72 chevy truck parts f/s. |
06-04-2010, 02:46 AM | #2 |
Recovering 67-72 Addict
Re: swb 1 piece drive shaft f/s
Interested but would like a measurement from centerline of u-joint to u-joint. I bought one of these off of the board before and it came up two inches short when I got it
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
06-04-2010, 08:37 AM | #3 |
It should be plenty long,especially if it was in a V8 truck.But,if not I`ll step in line next.I don`t have anything to measure,yet.I`m running a SBC/M22 to a 12-bolt.My transmission would be longer than a short shaft TH350,right?I know it bolts directly to the mount on the automatic crossmember.
06-04-2010, 11:00 AM | #4 |
i will try to measure this 1 today . i have some others about 52" for same price .
06-04-2010, 07:01 PM | #5 |
I forget...Is a 700r4 the same length as a TH350?
06-04-2010, 08:18 PM | #6 |
breeh it is 57 1/2 " .
06-04-2010, 11:22 PM | #7 |
Great, that is what I need. Just to confirm, that is from center eye to center eye? If so, that one has exactly the length that my other one is short.
Assuming the length is what I need, what is my total on the shaft and the groovy diamond tuck dash pad and pleated headliner (also assuming that the headliner is not warped)?
06-05-2010, 12:08 AM | #8 |
breeh that is 57 & 1/2" center u joint to center u joint but i will double check before you send money. the head liner has paneling for backing not plywood if that makes any drifference. i will also look at it again to see if i think it will stay where you put it when installed. i have paypal if that is how you would like to pay.
06-05-2010, 03:14 AM | #9 |
Paypal works for me. Let me know the total once you check out the headliner. Paneling is probably more pliable than plywood but I would like it to fit properly and not be bowed.
06-05-2010, 04:53 PM | #10 |
drive shaft is 57 & 5/8's center to center u joint. head is suppose to be held on by screws with a little washer about every 2 squares . it is bowed but its bowed up toward roof so it should look good and be out of the way when installed. everything would be $155.00 shipped or $120.00 if you don't want the head liner. i will pm you paypal info.
06-08-2010, 02:02 AM | #11 |
This one is [sold]
06-15-2010, 10:16 PM | #12 |
06-15-2010, 11:29 PM | #13 |
i think i have one that is 52" long but i am not sure i have a yoke.
06-16-2010, 05:00 PM | #14 |
thanks for looking I also measured wrong its more like 47 1/2
