06-04-2010, 12:27 PM | #1 |
6 lug rotors for 82 gmc 2wd
Does anyone know of anyone who sells these for a 1/2 ton 2wd truck
Thanks |
06-04-2010, 10:38 PM | #2 |
Addicted to Rust
Re: 6 lug rotors for 82 gmc 2wd
Try on the 67-72 side I think the 6 lug conversion rotors are the same as the 73 up 1 1/4 rotors. HTH Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
06-05-2010, 01:03 AM | #3 |
Standard 6-lug disc brake conversion rotors will work if you have the 1.25" HD brake option. If your truck is equipped w/the 'light duty' 1" brakes, it's possible that the last production year Astro van rotors might interchange.
06-05-2010, 10:56 AM | #4 | |
Still plays with trucks
If I had a 2wd square body spindle I would take my parts and give it a try.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-05-2010, 11:31 AM | #5 |
The C2500 new body style and the C10 square body call for the same Timken set 3 and set 5 inner & outer wheel bearings so it is possible the light duty C2500 rotors fit.
06-05-2010, 02:48 PM | #6 |
From what I've read, the bearings are correct; the position of the caliper to rotor surface is different on the 73-87 rotors vs. post 88's.
06-05-2010, 10:51 AM | #7 | |
I got the parts from a 93 light duty C2500 to convert my 67 C10 to 6-lug disc. The same setup will work on a square body too. You also need a different inner tie rod and 3/4-ton square body lower control arms and ball joints to complete the package. Half ton's use a smaller OD lower ball joint so the arms won't work.
06-05-2010, 09:57 PM | #8 |
Actually here is my dilemma I have a 68 that I am putting an 82 front end on so I can get disc brakes, and figured it would be easier to just hopefully find 6 lug rotors instead of swapping out the rear axle as well to have matching bolt pattern all the way around and figured i might get an answer out of the 73-87 guys because I havent been able to find just the rotors for sale the only thing Im finding is the whole 6 lug kit for the swap
06-05-2010, 11:01 PM | #9 | |
06-06-2010, 10:38 AM | #10 | |
They even fit inside my 15" Cragar Soft-8 wheels. http://67-72chevytrucks.com/vboard/s...51&postcount=9
06-06-2010, 01:54 PM | #11 | ||
CPP sells a 6-lug rotor that is a direct swap w/parts he already has.
06-07-2010, 11:14 AM | #12 | |
I paid less than $100 for the whole setup on my truck including the lower A-arms and new brake hoses so if he can get serviceable used rotors, calipers & front end parts it could be a less expensive route to go.
06-06-2010, 01:02 PM | #13 |
ok one last question, you say the new square body style C2500, what years is that considered?
Thanks Gregg Last edited by gregg72340; 06-06-2010 at 01:28 PM. |
06-07-2010, 11:06 AM | #14 | |
In 92 or 93 up the C1500 five lug rotors and the C2500 six lug rotors ride on the same spindle so it is possible to go this route for a five lug swap too.
