Amateur Build In Progress
I picked up a 1951 Chevy 5-window for a decent price just to learn "how to build a truck," about a year ago. I've never welded or done any body work. All I've done is read a lot of posts. Decided to go the S-10 route. It's been a lot more expensive and time consuming than I thought.
![]() ![]() Went with the EZ-Chassis Swap Since I could never fabricate something like this. As simple as it is, it still took us a couple of weekends to get it all on the frame. Like I said, I've never welded so my dad is teaching me as we go. ![]() Previous owner literally poured concrete in the drivers cab corner to fill the rusted holes. I had to chisel it out. Went ahead and had the cab media blasted. ![]() Sprayed some etching primer. ![]() Now we're in way over our heads cutting out the cab corners. We're trying to lip weld them because it is supposedly easier. I got the corners tac welded in place and we couldn't get the door to fit and had to take it off. Any helpful suggestions are appreciated. Keep in mind that I'm a novice with minimal tools/experience. ![]() I'll be slow with updates, because we are slow with our work Thanks. Last edited by Groyd; 05-18-2011 at 11:35 PM. |
Re: Be Gentle. . . I'm an Amateur.
Sweet man! Every one has a first build myself included keep at it and you will be a pro before you know it.. As for cab corners i tack tabs (from the inside) in and make it flush then you would have less filler
Exactly what C Low said, we all had to start somewhere and you are lucky, you got your Dad around to show you a thing or two. Keep up the great work and good luck!
66 GMC Suburban Custom 66 Chevy K10 Suburban Last edited by Southcity; 06-04-2010 at 07:02 PM. |
goin the club. both the corner on my 54 were filled with concrete too. must have been common thing on theses trucks.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
On my previous cab, one corner had, bondo, fiberglass and brass lol. Just keep at it and you will get there. Once I get back started on mine, I will be dealing with the same learning curve.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
Cancer Survivor in the making.
Welcome! You can always come here and ask questions when you find challenges. Even experienced guys with lots of builds behind them do that.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
Groyd,
If you do some searching, you'll find my first attempt at building a truck. I too went the s10 route, thinking less money and a fews weekends of time would yield a drivible piece of Americana. Fast forward two + years and I still have an steel dream my wife doesn't understand. Through all of the head scratching and cus words, I have learned that if I give it enough time and effort, I will get something I'm truly proud of; not something from a shelf. That should be your focus. Ask as many questions as you can, and learn from your mistakes because there will be a few. This board is as nice as they come. Good luck and keep moving forward. We have all been, or are standing now, in your shoes. Jeff Last edited by jeffs51chevy; 06-04-2010 at 08:29 PM. |
#16876
First, Welcome to the board. Second, Slow? Wow you are moving at the rate of a gazelle. If you can't get to sleep see my build thread (link below) it started three years ago and it's way far away! Good job.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. Last edited by Sillyoldman; 06-04-2010 at 09:09 PM. |
My cab was loaded with rat $h!t.
I forgot to mention. I bought a 5.3 out of an '04 GMC from my cousin. Engine, trans, and computer. He said he could wire it up. I guess we'll see once were done with this cab. I'll try to get a pic of it up tomorrow sitting on the frame.
Amateur Build in Progress.
Sat it in the frame just to get an idea if my motor mounts would work with the LS type engine. Still won't be certain until we get the cab in place. Kind of hard to do since the body is at my parents house.
![]() I'm going to have quite a bit of slide room if it needs adjustment forward or backward. ![]() |
#12 | |
Re: Amateur Build in Progress.
The mounts from the motor are LS plates to SBC mounts (I believe they were Trans Dapt brand). Then, like you mentioned, the S10 Frame to SBC mounts from EZ.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
Certified Car Nut
Looking good keep up the good work.
#15 |
Dude! Very nice! Keep plugging away and it will be a driver.
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#16 |
Since the doors wouldn't shut with the cab corner tac welded in place. We had to remove the corners. . .again. . . and try to fit the doors. Needless to say, the hinges and latches were shot. I had already ordered some replacement latches.
![]() ![]() We got the latches and new hinges installed but we're still having trouble lining up the door to shut. Any suggestions on how to line up the doors? Has anyone used washers to shim up the mounts? Top of driver's side door: ![]() Looking down on passenger's side: ![]() |
#17 |
if you havent rebuilt the hindges start there. Then hang the doors.
#18 |
We installed new ones. Still having trouble though.
#19 |
6>8 Plugless........
![]() Join Date: Sep 2007
Yes you can use washers or go to a body parts supply house and get some shims. You can cut slots out of washers as well but the shims are easier to use since they have a tab to hold on to them or grab them. Atleast you hung the door before you welded the cab corner on. A lot of people don't do that and have to cut the complete patch out and start over. Nice job, and keep up the great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#20 |
your making some nice progress keep up the good work.
#21 |
Welcome, I think most of are amateurs here. I know I have a lot of mechanical knowledge but the body stuff is driving me nuts. I did the cab corners, front floor, firewall and outer cowl on my dads 52. The thing I am learning about all these replacement parts is that you don't have to use the whole panel. I am hard headed so I tend to think that I have to use everything the ship me. If I had to do it over again I would only use what was needed to replace the rust. I think I have some pictures of the door hinges that I rebuilt on my build thread. If not let me know and I will see what I got here on the computer. Another thing with the hinges is that you may have to loosen the bolts that hold the door to the hinges and jockey the door around. I think I messes with the drivers door for a full day before I got it where I wanted it. Good luck and don't hesitate to ask questions there are lots of knowledgeable people on this board.
Bernie |
#22 |
This guy showed how he got his doors aligned. It looks like you will have to tweak your hinges too. Hope this helps http://www.chuckthetruck.com/page20.html
#23 | |
I think we've come to the agreement that it would be better to pay a body shop to fix our body work and door problems if we can't figure it out pretty soon. I'm pretty cheap though, so we'll see. |
#24 |
Have you checked out the Oklahoma section? We have been talking about trying to go to some of the Coit's cruise nights around the metro. I am happy to see another AD truck up here, especially one making more progress than I do lol.
#25 |
Sounds like a good idea, bjcaldwe.
