700r4 leaking from yoke while jacked up or on a hill
i jus had my engine pulled and while the tans was jacked up it leaked out a bunch of trans fluid. the guy told me that it was leaking out of the yoke. he also told me that it wouldn't be a problem to just plug the hole in th yoke to keep it from leaking. anyone had this problem.
Garage wrench
Re: 700r4 leaking from yoke while jacked up or on a hill
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Thanks for the info. Mines a 400turbo but I've noticed when i have mine parked in the drive way ( whice is a pertty good hill) there would be trans fluid on the ground when i moved it. I'll check into the o'ring.
85 Chevy C-10 383 stroker |
thanks a lot
.. !WAR FEDOR! ..
[QUOTE=SBTork;4015407]DO NOT PLUG THE HOLE!!!
Do this instead....http://73-87.com/7387garage/drivetrain/yokeleak.htm[/ just out of curiousity, why not?
"san diego chargers #1" |
Most trannies that have been rebuilt no longer have that sleeve. Millions of trannies dont have the hole in yoke at all. I vote tack weld the hole shut and call it a day.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#9 | |
Garage wrench
[quote=joe1982;4017633]
I could have sworn that I remember reading somewhere that the hold is needed for something but I cannot remember what. Obviously it is not needed for anything according to others, it would be cheaper and just as effective to just weld it up, so go for it.
gets board easy.......
i plug the hole with Silicone, works everytime
Plugged mine about 2 years ago. No problems since.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
what about a th350? mine does the same thing if i park in the driveway or leave it sitting for a while.
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
#13 | |
Insert Witty Text Here
Before that, I had just sprayed the hole with brake cleaner to clean it up and dabbed some RTV on it with the tip of a screwdriver. That worked, but it had to be replaced once a year or so. I eventually had to buy a new yoke from a drivetrain shop. They sold me one with no hole, and said they weld up EVERY one they work on. Slonaker |
Its the same setup in a th350. Just plug the hole. A lot of yokes didnt even have the hole in the first place.
