?? electric speedo to cable speedo
I just got my 72 burb roadworthy but the 700r4 has electric speedo connection. Can it be changed to the the cable driven type and what is needed?
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
![]() Join Date: Jun 2007
Re: ?? electric speedo to cable speedo
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Too Dumb To Know Better
Yes, you can get another tailhousing. Street and Performance sells them.
![]() Join Date: May 2002
my new transmission was supposed to use the electrical speedo connection, but I just installed the cable style, which I already had, and it fit just fine. I didn't have any problems with it, just make sure you use a new o-ring seal. I didn't have to change the tailhousing at all.
Of course you will need the cable housing, driven gear, and the o-ring seal. I suggest the aluminum housings, since the plastic ones can break. Here is a thread with the part numbers and other info: 700R4 Info.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 06-06-2010 at 09:28 PM. |
Thanks. Thats more like what I had in mind. Does the electronic version also use the "drive" gear and is it the same for cable version?
Yes, the drive gears are the same.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
cool, I just need to find a donar tranny
Too many projects
To switch you need to pull the tail housing off, pull off the reluctor wheel (metal wheel) and slide on the plastic speedo wheel, bolt up the tailshaft and toss the cable drive on the outside and the party is done!
I did it on my 67 in about 30 minutes and didn't loose much in the way of ATF.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
thanks for the description of the change. I have not tried anything yet as I have been busy on a few other things but hope to get to it soon.
I'm facing the same problem on my TH400 in my 454/auto swap
