I was wondering if anyone has used any other type of header instead of the one for our trucks, such as the chevelle, or hugger style. I am looking at getting the hugger style for my truck and would like to know if anyone tried and would like to know if there are anythings that I should watch out for.
They are going on my 83 with a 350/th350 ------------------ New Project
http://members.xoom.com/luc_nt
1972 Chevy C-10 Short Stepside 6Cyl, 3 spd, not opts (Current Project) Now a 2004 SSR 5.3L with 4L60E Now Ididit tilt- ps, pb 2002 Saturn L200 2006 Toyota Highlander HYBRID |
Top, anyone???
BAD BOW-Silverado XST
I dont know about the block huggers fitting in our trucks. You would have to cusom make some pipe to get them all the way out. Will you be using a single out or double pipe? Single cat or muffler? I personally will probably go with full length headers. Edelbrock makes some for our trucks and even has a set for lowered truck. If you look under my truck the only thing sticking past the body line is the exhaust "Y" pipe. I've had to remove road debri more than once off the thing. If you go tiwht the block huggers let us know how you worked around the frame and engine bay. My guess you are not worried about state inspections. That's a plus!!
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I am going to use Sanderson Chevelle headers on my 454. Block huggers with a center dump are going to cause you some interference problems with the frame and motor mount perches.
------------------ Chris Lucas 1973 Chevy C-10 1975 Chevy Silverado Captkaos' Page
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Thanks for your input. I am looking at true duals, with mufflers only. I think that I might look into the edelbrock lowering headers.
| Bookmarks |
