Too Dumb To Know Better
and more brake issues
I recently converted my Jimmy to 2 wheel drive. I have new rotors, calipers and pads. The first few times I stop everything is OK. Then it appears that the left calper sticks engaged. Brakes get real hot. After cooling for awhile, they work great and then start the process all over again. Short of never using them, what do you suspect?
Thanks. Last edited by low'n slow; 06-12-2010 at 09:52 PM. |
Happy to be here
![]() Join Date: Mar 2000
Re: and more brake issues
Check for brake pad overlap. Seen it cause the pad to stick before, but usually on happens after a few miles are on the pads.
What is brake pad overlap? it has about 15 miles on it.
do you have a proper disc/drum master cyl and proportioning valve assy? using a drum/drum srtup will cause the calipers to bind up and overheat
if they overheated you need at least new pads and to check calipers for warping
#5 | |
Did you replace the rubber lines? There have been issues with them collapsing internally, causing random dragging
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Happy to be here
If it only has 15 miles on the system then pad overlap is not a concern.
To answer your question, pad overlap is when the pads are glued on the backing plates to far outboard. As the wear, a portion of the pad remains intact protruding out from the worn pad surface. This can cause your pads to stick to the rotor and not release.
Yes, I have the proper master cylinder and proportioning valve. All new steel and rubber lines.
Grandpa in the rustmobile...
adj. rod OR (i had an extra gromit betwen booster/mc causing brakes to stick)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
If the rod was too long, wouldn't it cause to brakes to drag all the time? This only drags after the brakes are used a few times.
If the rod was too long, both sides would drag, not just one. There is a similar thread running on the 67-72 board right now, still not fixed. Look for "At my wit's end".
I suggested checking for bent pins (that the caliper slides on). Haven't got an answer to that post yet. Ray |
The rod was too long. I shortened it, freshened up the brakes and all is well. Thanks for the help
