Frame differences in 67-72 Suburban?
Looked a bit and did not see anything on this topic...was wondering if there are any frame differences between a 68 and a 72 Suburban 2wd and 1/2 ton? Think I am going to do a frame off on my '72 and I have a '68 laying around...so thought I would do all my suspension work and frame strip and powdercoat on the 68 frame so I would not have to take down my '72. Then just swap my 72 Suburban tub onto the '68 frame when it is nice and perty.
So, help me a bit and lmk if there are any differences in the frames so I can ponder whether to do it this way... As always thanks in advance for your knowledge and wisdom! Adam |
Re: Frame differences in 67-72 Suburban?
The only difference I can think of would be the axles and front suspension, but I am assuming you will be redoing all that, and possibly the area by the Power Steering pump if there is no dimple for it
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
Exactly, will be swapping rear end and front crossmember for 5 lug and end up with 4 wheel disc brakes too...thanks for the input. Any one else??
