Old 06-15-2010, 02:17 PM   #1
rjn72
rjn72's Avatar
how do I take off door?
I bought a power windows, locks door from a gentleman over the phone and I have to go get it. I have never pulled one off before. How do I get the door off without cutting the wires. Which end do they unplug? Any special tricks you know of. Door is coming off of 1987 suburban and it is the rear door. Thanks for the help in advance guys.
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 06-15-2010, 02:18 PM   #2
rjn72
rjn72's Avatar
Re: how do I take off door?
passenger side back door.
JESUS IS LORD
Old 06-15-2010, 02:22 PM   #3
GMC91
Always trouble
GMC91's Avatar
To take off the door, it should be pretty simple, 6 bolts and its off. 3 on the top hinge and 3 on the bottom. As for the wiring, I have no clue, never delt with power windows or locks.
91 Silverado Regular cab, 2wd, swb-project truck
97 Silverado Extended cab, 2wd, swb-driver
GMC91 is offline   Reply With Quote
Old 06-15-2010, 02:24 PM   #4
Jonboy
Slots go on anything!
I would pull the trim panel, and unplug the lock motor and window motor, then remove the bolts. go back and trace teh wiring in the cab, and unplug it there.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 06-15-2010, 03:05 PM   #5
lo72
Truck Junkie
lo72's Avatar
The wiring is inside the cab right by the kick panel it will be 2 plugs
lo72 is offline   Reply With Quote
Old 06-15-2010, 07:44 PM   #6
westofb
I really hate wet sanding!
westofb's Avatar
And you will really enjoy getting to them to unplug them! I am especially fond of unplugging the drivers side!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 06-16-2010, 12:07 AM   #7
rjn72
rjn72's Avatar
Thanks alot. It sure makes it easier to do something if someone gives you some info first. Thanks for the help guys.
JESUS IS LORD
