Old 02-15-2003, 11:22 PM   #1
r0lf-
Hotwheels?
r0lf-'s Avatar
275/60/15's up front with a 3/5?
Well... im about to order my 3/5 drop with spindles and a flip kit, my question is... will my 275's rub up front bad? I am eventually going 255/60/15's up front, but could I run them for a while? I want to finish with a 5/5 or a 4/5 drop eventually. Any advise?
r0lf- is offline   Reply With Quote
Old 02-15-2003, 11:45 PM   #2
AirMale
AirMale's Avatar
I ran 275/60/15's front with 2 1/2" spindles and had over an inch clearance. Should be no prob
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 02-16-2003, 12:45 AM   #3
ocbaud
Garage Queen Material
my front's rubbed on the fender lips when i was turning and hit a big bump. i rolled the fender lips a little and it helps A LOT. my drivers side tire is about even with the wheel well, and my passanger side is about 1/2" from being even
ocbaud is offline   Reply With Quote
Old 02-16-2003, 02:00 AM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
I'm thinking if you are going with 3" spindles, you should be fine as far as the tire rubbing. This shouldn't change the geometry and throw the camber out so bad it pushes the wheel out. With coils, you end up with negative camber and a lot of shims have to be used to get it back right. This in turn pushes out the wheel and would probably hit the fender lip. But again, I think 3" spindles will be OK. You will probably need to do a little grinding on the lower control arm though. Your 15" wheels are going to rub.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-16-2003, 08:23 AM   #5
Razorback_Fan
Razorback_Fan's Avatar
Post some pics when you get it completed. I still can't decide on how low to go yet.
Razorback_Fan is offline   Reply With Quote
Old 02-17-2003, 03:44 PM   #6
Low87
been here longer than Liz
Low87's Avatar
I ran that and had my inner fender edge cutting into my sidewalls.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-17-2003, 03:59 PM   #7
r0lf-
Hotwheels?
r0lf-'s Avatar
Did you roll your fenders? Because Im pretty sure im going to be doing that.
Old 02-17-2003, 04:10 PM   #8
Low87
Low87's Avatar
I didn't roll my fenders.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
