Old 06-15-2010, 09:59 PM   #1
minime's 68'
axle question
Does anyone know if in 1970 3/4 ton axle if they made floating and semi floating 14 bolt? I have a 1968 and I put axles from a 1970 3/4 ton and I'm wanting to put disc brakes on the rear, cause I'm having a prob. with the rear drums locking up even when I back off the brakes. I'm wondering if putting disc brakes on the rear would fix the prob. Any help would be much appreciated!
minime's 68' is offline   Reply With Quote
Old 06-15-2010, 10:18 PM   #2
b454rat
Re: axle question
Dunno bout the brakes, but only semi float axles in those days were the 1/2 ton stuff. All 8 lugs were full floaters, either Eatons or Dana 60s.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-16-2010, 12:04 AM   #3
milled
milled's Avatar
Re: axle question
did you try beeding the brakes. Check for a stuck e-brake cable.
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
